Closing the loop based on discussion with NETMF devs : They will be forcing use of the pre-Roslyn compiler (the VS2013 compiler), so this issue will go away for VS2015 targetting NETMF 4.4. If you want to use VS2015 targetting NETMF 4.3, you can use the workaround that I posted above.
