[VB] Shift operator is giving error "BC30002: Type 'System.Nullable(Of )' is not defined"
In VB.Net running on VS2012, when using the shift operators (<< or >>), the following error is generated:
error BC30002: Type ‘System.Nullable(Of )’ is not defined
Am I missing a reference?
This happens when using either the 4.2 or 4.3 version.
From a default NetMF console app:
Option Explicit On
Option Strict On
Imports Microsoft.SPOT
Namespace MFConsoleApplication1
  Public Module Module1
    Sub Main()
      Dim a As Integer = 192
      Dim b As Integer
      b = a >> 1
      Debug.Print(b.ToString)
    End Sub
  End Module
End Namespace
Interesting problem! I suggest you get this reported directly to Microsoft https://netmf.codeplex.com/
