I have added a small bitmap (30 pixels x 30 pixels) to the project resources folder and wish to load it onto the T35 display. I have guessed at setting properties for the bitmap as “Build Action: Embedded Resource” and “Copy to Output: Copy Always”.
My VB code looks like this so far and doesn’t work.
Dim picture As Bitmap
picture = New Image("BlueSlider.bmp")
Display.SimpleGraphics.DisplayImage(picture, 0, 0)
Any help much appreciated.The only information I have relates to loading images from an SD card. I would rather not do so for this project.
Mainboard used is a Fez Spider.
it’s not enough only add the bitmap to the folder.
you have to doubleclick the “Resources.resx” in the project-explorer and then using the “add” function to register the resource
