I am working on a program that has an integer counter this counter is deffined in Main as int Count;
i have a interrupt service routine that is used to update the variable Count
when i use Count in the ISR it is not recognised
Error 1 An object reference is required for the non-static field, method, or property ‘FEZ_Panda_II_Application1.Program.count’ e:\QUADRATURE example\QUADRATURE example\Program.cs 45 11 QUADRATURE example
