Tony
1
The spacing between the uUSB and the USB connectors are too close to each other.
If I have the uUSB cable plugged into my dev PC I can’t plug a USB thumb drive into the FEZ board since the connectors are too close.
Maybe this can be adjusted on newer boards.
Your USB drive must be large! You can use extender cables which usually ships with those large USB drives
Tony
3
I have a standard Cruzer USB drive and it doesn’t fit.
Come on guys, make the next board revision so there is more space!
Thanks,
Not sure if design will ever change on our side…it is open source design so anyone is welcome to take the design and a changer it anyway they like.
With that in mind, we will look into it in future to see if we can distance the connectors.
