Using USB Host
I want to use the USB Host feature of my FEZ Domino for USB debugging.
I want to list all configuration, interfaces and endpoint of the connected USB device. I done most of the work but I didn’t found how to get the string descriptors (like the Manufacturer string etc)
exemple : I can get iInterface (the id of the string descriptor with the interface name), but I couldn’t find a GetStringDescriptor method, and the auxiliaryDescriptors array is empty…
Is there a way to do that?
In case you don’t know we have something that might help on Fezzer:
http://www.fezzer.com/project/164/usb-discovery-helper/
Thanks, I didn’t know about this helper, I wrote my own, but like mine, this one do not get string descriptors…
Is there a way to get them?
Anything is possible with FEZ :wink:
Try this:
using System.Text;
using GHIElectronics.NETMF.USBHost;
            USBHostController.DeviceConnectedEvent += new USBH_DeviceConnectionEventHandler(USBHostController_DeviceConnectedEvent);
            USBHostController.DeviceDisconnectedEvent += new USBH_DeviceConnectionEventHandler(USBHostController_DeviceDisconnectedEvent);
        static void USBHostController_DeviceDisconnectedEvent(USBH_Device device)
            Debug.Print("Device disconnected. ID: " + device.ID);
        static void USBHostController_DeviceConnectedEvent(USBH_Device device)
            Debug.Print("Device connected. ID: " + device.ID);
            USBH_RawDevice rawDevice = new USBH_RawDevice(device);
            // contains some strings indices
            USBH_Descriptors.Device dd = rawDevice.GetDeviceDescriptor();
            Debug.Print("Manufacturer: " + GetUSBString(rawDevice, dd.iManufacturer));
            Debug.Print("Product: " + GetUSBString(rawDevice, dd.iProduct));
            Debug.Print("Serial Number: " + GetUSBString(rawDevice, dd.iSerialNumber));
        static string GetUSBString(USBH_RawDevice rawDevice, byte stringIndex)
            if (stringIndex == 0)
                return "";
            try
                byte[] temp = new byte[1];
                // read string size first
                rawDevice.SendSetupTransfer(0x80, 0x06, (ushort)(0x0300 | stringIndex), 0x0409 /*English*/, temp, 0, temp.Length);
                // allocate new size
                temp = new byte[temp[0]];
                // read string
                // convert to ascii. skip first two bytes.
                char[] stringChars = new char[(temp.Length - 2) / 2];
                for (int i = 0; i < stringChars.Length; i++)
                    stringChars[i] = (char)temp[2 + i * 2];
                return new string(stringChars);
            catch
                return "";
Thanks!
It’s exacly what I need ^^
I’m a noob in USB (started a week ago) and I never knew I could get them with low-level command like SendSetupTransfer()
Is something like this to be implemented in future versions of the GHI SDK?
PS. Sorry for my bad english…
