Using the DispatcherTimer in Glide
Dear all
Unfortunately, I’m not able to use the DispatcherTimer to call a method periodicly in the UI.
// Updates the time every second
DispatcherTimer timer = new DispatcherTimer();
timer.Tick += new EventHandler(OnTimer);
timer.Interval = new TimeSpan(0, 0, 1);
timer.Start();
This example is from the GHIGraphical Taskbar demo. I’d like to use the same functions to update a time text in the LCD.
If anybody has any idea or solution, please share it with us :wink:
Regards J.
Whats the error? Show some more code.
No error occurs, the timer doesn’t call the OnTimer.
            Glide.FitToScreen = true;
            // Tell Glide to use our custom keyboard.
            Glide.Keyboard = InitKeyboard();               // Load the window
            window = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.Window));
            // Activate touch
            GlideTouch.Initialize();
            // Initialize the window.
            timer.Start();
            Glide.MainWindow = window;
            Thread.Sleep(-1);
        static void OnTimer(object sender, EventArgs e)
You know this means the timer will fire every minute?
To fire every second:
timer.Interval = new TimeSpan(0, 0, 0, 1, 0);
Both of your code snippets fires every second.
public TimeSpan(int hours, int minutes, int seconds);
public TimeSpan(int days, int hours, int minutes, int seconds);
public TimeSpan(int days, int hours, int minutes, int seconds, int milliseconds);
Can you try and replace Thread.Sleep( -1 ) with
    Dispatcher.Run();
If that works, then it means there is no Dispatcher running in your application (you have no Application object, f.e. in a Console Application)
See http://www.tinyclr.com/forum/1/3953/#/1/msg37313
Use a regular Timer. Gilde doesn’t use the Dispatcher to make things more optimized.
