did you change the name of the namespace of the SerialBuffer class into the name of the namespace of your project?
this in ProgramStarted part.
SerialBuffer mySerialBuffer = new SerialBuffer(256);
something to print only after a “\r\n” was sent
Edit:
sorry;
SerialBuffer mySerialBuffer; //
it seems to not change anything.
it says :
" if (lineEndPos > 0)" = false and skips it all
can you Show the code and the error Messages?
what did you send?
i use the program “terminal” to send “test”
as an message. and want that to be displayed on the char display.
im now using this code for reciving it but it doesnt seem to work.
rs232.Initialize(38400, GT.Interfaces.Serial.SerialParity.None, GT.Interfaces.Serial.SerialStopBits.One, 8, GT.Interfaces.Serial.HardwareFlowControl.NotRequired);
rs232.serialPort.DataReceived += serialPort_DataReceived;
void serialPort_DataReceived(GT.Interfaces.Serial sender, System.IO.Ports.SerialData data)
byte[] myBuffer = new byte[rs232.serialPort.BytesToRead];
rs232.serialPort.Read(myBuffer, 0, myBuffer.Length);
mySerialBuffer.LoadSerial(myBuffer, 0, myBuffer.Length);
string dataLine = "";
while ((dataLine = mySerialBuffer.ReadLine()) != null)
Debug.Print(dataLine);
and the serialbuffer.cs from that other post. it goes into that till the point it reaches :
if (lineEndPos > 0) and returns null.
my old code gave me this(in the debugger console, not the char display) :
T
e
s
t
old code :
int B2R = sender.BytesToRead;
int myChar;
var printstring = "";
for (int i = 0; i < B2R; i++)
myChar = sender.ReadByte();
char converted = (char)myChar;
printstring = printstring + converted;
Debug.Print(printstring);
perhaps you don’t send with CRLF.
Check +CR on your terminal program
ive tryed it with on and off.
just tried, for me the SerialPort Class works,
try this faked message with CRLF
// byte[] myBuffer = new byte[rs232.serialPort.BytesToRead];
// rs232.serialPort.Read(myBuffer, 0, myBuffer.Length);
byte[] myBuffer = new byte[5] { 0x51, 0x52, 0x53, 0x0d, 0x0a };
//Debug.Print("arrived");
did you open the port?
rs232.serialPort.Open();
rs232.serialPort.DataReceived += new GT.Interfaces.Serial.DataReceivedEventHandler(serialPort_DataReceived);
Yes… and i cant get it to work.
if it works theire. can i get your source code? :
Yes, send me a “Direct Message” over my Profile with your E-Mail Address.
But I have to do other things in the next hours.
@ rayhvh - Use the debugger to single step and determine what is happening or add Console.Debug messages to tell you what is happening.
@ rayhvh -
Set these two checkboxes on your terminal an it should work
@ rayhvh -
now I have tested with the rs232Module (did before with the usbSerial Module) and it really did not work.
Brett’s eventhandler was the right one.
Here is now the code tested with the rs232 Module:
// This is a little test-program for Cobra 2 with a rs232 Module or usbSerial Module
// Data are received over the serial connection and are output to Debug.Print after
// the delimiter Hex 0x0A is received
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace Serial_Test_Snippet
public partial class Program
// this is for use with the rs232-Module ************************************************************
try
catch (Exception e)
Debug.Print(e.ToString());
if (!rs232.serialPort.IsOpen)
rs232.serialPort.DiscardInBuffer();
rs232.serialPort.DataReceived +=new GT.Interfaces.Serial.DataReceivedEventHandler(serialPort_DataReceived);
// this is for use with the usbSerial-Module ************************************************************
try
usbSerial.Configure(38400,GT.Interfaces.Serial.SerialParity.None, GT.Interfaces.Serial.SerialStopBits.One, 8);
catch (Exception e)
if (!usbSerial.SerialLine.IsOpen)
usbSerial.SerialLine.Open();
usbSerial.SerialLine.DataReceived += new GT.Interfaces.Serial.DataReceivedEventHandler(SerialLine_DataReceived);
byte[] myBuffer = new byte[sender.BytesToRead];
sender.Read(myBuffer, 0, myBuffer.Length);
void SerialLine_DataReceived(GT.Interfaces.Serial sender, System.IO.Ports.SerialData data)
byte[] myBuffer = new byte[usbSerial.SerialLine.BytesToRead];
usbSerial.SerialLine.Read(myBuffer, 0, myBuffer.Length);
[quote=“rayhvh”]
thanks that works!! 8)
