Using Seeed Studio Cellular Radio Module in FEZ Cobra II using Socket Type U?
Is it possible to use Seeed Studio Cellular Radio Module in FEZ Cobra II using Socket Type U (instead of K)?
best regards
Laurentius
@ Laurentius - the difference between a U and K socket is a K socket supports hardware flow control. If the Seeeed driver uses flow control, then you must use K socket.
@ Mike - I am not planning to use Gadgeteer but direct serialport (COM1) without hardware handshaking. I noticed after getting the device that it needs K type socket :confused:
@ Laurentius - you might have to do a bit of wiring to simulate flow control. lookup RTS and CTS.
