I was experimenting with using the Register class to implement a parallel I/O port.
Chose the FEZ MINI because it has 13 contiguous bits (P0.16 � P0.28) brought out to the headers.
I attached a picture of the timing waveform from my logic analyzer and the code file.
NOTE: The first 2 lines in the Main (disabling the SPI?) were not in the original test�something I added this morning and plan to try out this evening.
The signals (top-to-bottom) are:
CS-Chip Select-ADC1
RS-Register Select-ADC2
WE-Write Enable-ADC3
D0-Data Bit 0-P0.16
D1-Data Bit 1-MISO0 (never changes)
D2-Data Bit 2-MOSI0 (never changes)
D3-Data Bit 3-SD_CLK
D4-Data Bit 4-SD_CMD
D5-Data Bit 5-SD_PEN
D6-Data Bit 6-SD_DAT0
D7-Data Bit 7-ADC0
You�ll notice D1 and D2 don�t change�these are MISO0 and MOSI0 pins�which is my dilemma…all other signals are �as expected�
According to my logic analyzer, the time between CS rise (8 writes) is around 2.15ms so that should result in 3720 single byte writes per second ((1/0.00215)*8)�writing to a 40x24 character display would take around 0.25 seconds(?)
My initial question:
Will clearing the PCSPI bit of the PCONP register disable the SPI and thus cause my D1 and D2 signals to output?
Can’t attach files so pasted code:
using Microsoft.SPOT.IO;
using GHIElectronics.NETMF.Hardware.LowLevel;
namespace RegisterTest1
private static uint CS = 0x01000000; // nCS 0xFEFFFFFF Use &
private static uint RS = 0x02000000;
private static uint WE = 0x04000000; // nWE 0xFBFFFFFF Use &
private static uint OE = 0x08000000; // nOE 0xF7FFFFFF Use &
private static uint TR = 0x10000000;
private static Register FIO0DIR = new Register(0x3FFFC000);
private static Register FIO0MASK = new Register(0x3FFFC010);
private static Register FIO0PIN = new Register(0x3FFFC014);
private static Register PCONP = new Register(0xE01FC0C4);
public static uint mCurrentDir;
public static uint mCurrentMask;
// static Register FIO0SET = new Register(0x3FFFC018);
// static Register FIO0CLR = new Register(0x3FFFC01C);
// static Register SCS = new Register(0xE01FC1A0);
// NOTE: These 2 lines were NOT part of the initial test !!!!!!!
uint lCurrentSPI = PCONP.Read();
PCONP.Write(lCurrentSPI & 0xFFFFFEFF);
uint lCurrentDir = FIO0DIR.Read();
uint lCurrentMask = FIO0MASK.Read();
FIO0DIR.Write(lCurrentDir | 0x1FFF0000);
FIO0MASK.Write(0xE000FFFF);
bool lCont = true;
while (lCont)
uint y;
uint z;
FIO0PIN.Write(CS); // CS=1
y = CS | RS;
for (uint x = 0x00010000; x < 0x01000000; )
FIO0PIN.Write(y); // CS=1 RS=1
z = y | x;
FIO0PIN.Write(z); // CS=1 RS=1 DATA (Setup Time)
z = z | WE;
FIO0PIN.Write(z); // CS=1 RS=1 DATA WE=1 (Data Write)
z = y | x;
FIO0PIN.Write(z); // CS=1 RS=1 DATA (Hold Time)
x = x << 1;
FIO0PIN.Write(0x00000000); // Clear all bits
FIO0DIR.Write(lCurrentDir);
FIO0MASK.Write(lCurrentMask);
PCONP.Write(lCurrentSPI);
