Does any one have good/bad experiance with NuGet.
Currently I’m using a self made VS Plugin to manage my dependencies.
My Plugin supports:
- Add/remove dependencies.
- Reference only a subset of dll per package
- Specify version to use
- Limit versions to use
- Recursivly add packages
- Check for version conflicts
- Automatically update all versions (and other data) in AssemblyInfo.cs of each project in solution
- Quickly switch between versions to use
- Use a locally build ‘Package’ instead from server
- Create Pre-Release Package
- Create Release Package
- Create a ‘Customer Version’ which contains all required dependencies to run.
- Work offline by copying all packages to a local folder and switch to it when server is not available
All directly from within Visual Studio
So I have 2 questions:
Can NuGet do this as well?
Would you recommend using NuGet in general?
