I tried to create a new Gadgeteer project for MF4.3 and Raptor board with an SD Card module. An exception is thrown on this statement in the Designer generated code, program_generated.cs:
private void InitializeModules() {
this.sdCard = new GTM.GHIElectronics.SDCard(9);
In my Program.cs, an exception is thrown when I call sdCard.Mount(). A FAT32 formatted card is already inserted. This same card worked using MF4.2 on Raptor. It has files on it that are readable on a PC SD card reader.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace SDCardTest
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
sdCard.Mounted += sdCard_Mounted;
sdCard.Unmounted += sdCard_Unmounted;
Debug.Print("SD Card is inserted = " + sdCard.IsCardInserted.ToString());
Debug.Print("SD Card is mounted = " + sdCard.IsCardMounted.ToString());
if (!sdCard.IsCardMounted)
new Thread(MySDCardMounter).Start();
void MySDCardMounter()
sdCard.Mount();
void sdCard_Unmounted(SDCard sender, EventArgs e)
Debug.Print("SD Card was un-mounted");
void sdCard_Mounted(SDCard sender, GT.StorageDevice device)
Debug.Print("SD Card was mounted");
A first chance exception of type âSystem.Exceptionâ occurred in GHI.Hardware.dll
The thread ââ (0x4) has exited with code 0 (0x0).
Program Started
The thread ââ (0x3) has exited with code 0 (0x0).
Using mainboard GHI Electronics FEZ Raptor version 1.0
#### Exception System.Exception - 0xffffffff (1) ####
#### Message:
#### GHI.IO.Storage.SDCard::NativeConstructor [IP: 0000] ####
#### GHI.IO.Storage.SDCard::.ctor [IP: 0017] ####
#### SDCardTest.Program::InitializeModules [IP: 0005] ####
An unhandled exception of type âSystem.Exceptionâ occurred in GHI.Hardware.dll
timer.Start();
new Thread(sdCardTest).Start();
void sdCardTest()
// if necessary, check that SD is present here...
SDCard sd_card = new SDCard();
sd_card.Mount();
bool fs_ready = false;
RemovableMedia.Insert += (a, b) =>
fs_ready = true;
while (! fs_ready ) {
System.Threading.Thread.Sleep(1);
// Assume only one storage device is available
// and that the media is formatted
FileStream FileHandle = new FileStream(rootDirectory +
@ "\hello.txt", FileMode.Create);
byte[] data =
Encoding.UTF8.GetBytes("This string will go in the file!");
FileHandle.Write(data, 0, data.Length);
FileHandle.Close();
sd_card.Unmount();
I think itâs telling you what your problem is (like all exceptions tend to )
Invalid Driver.
IMHO that means youâre doing it all wrong and the driver youâre invoking is not the one that is meant to leverage the SD card. I suspect that this is an artefact of the way youâve done things earlier to work around whatever other issue you were having. You probably need the SD Card object to be created outside the thread so it doesnât get GCâed
