Gus, just wanted to let you know I finally got this working. Before I was running the Panda II and Touch display from the USB power. It worked fine as long as the Touch display was plugged directly into the Panda II, but when I attached it with a cable the touch interface stopped working. I thought the problem was with the Touch ribbon cable, but I recently tried it with a 6.5 volt external supply and it worked
