Hello Everyone,
I’m new to NETMF ang Gadgeteer subsystem and also I’m kind of slightly confused of all that libraries ierarchy. I mean there is NETMF libraries, Gadgeteer core, GHI-specific and so on. It is not very clear for a beginner how these libs must interact with emulator.
So when I start a new Gadgeteer application (4.2 runtime in VS2012) I choose a FEZ Raptor mainboard. Then in designer view I add LCD43 module and connect it properly to a mainboard.
And when I run the application in debug mode (deploying to MS emulator) the exception occurs: An unhandled exception of type ‘System.NotSupportedException’ occurred in GHI.Premium.Hardware.dll
this exception occurs within the GHIElectronics.Gadgeteer.FEZRaptor.SetLCDConfiguration() method, on line:
if (Configuration.LCD.Set(config))
But in case I remove LCD43 module then application launches successfully on emulator.
Is this some issue with my code/environment or I cannot run such application on emulator at all?
