I would like to solder a wire right on top of a USBizi GPIO that isn’t broken out to a header pin. Before I do this…(well it wouldn’t be me ) I would like to know if the GPIO driver for the Domino board includes all pins, even ones that aren’t connected to a header ?
Mmm, if you use Object Browser in VS you can expand the GHIElectronics.NETMF.Hardware.USBizi assembly and see what pins are defined. Do the same in the FEZDomino_GHIElectronics.NETMF.FEZ FEZ_Pin.Digital and you should see the plethora of pins defined.
There’s no difference between the USBizi chip and what’s on the Domino. If you have fine enough wire to solder directly and have checked the schematic to ensure the pin is not in use - then go for it i say.
