Migrating from 4.2 to 4.3 i’m able to map:
USBHostController_DeviceConnectedEvent -> Controller_DeviceConnected
USBHostController_DeviceBadConnectionEvent -> Controller_DeviceConnectFailed
but i don’t find a event for: USBHostController_DeviceDisconnectedEvent
How do you handle a USB device that is removed?
Did you find USB_Device? What namespaces are you using? I didn’t find it either.
The 2 events i found in : GHI.Usb.Host.Controller.
Did you find GHI.Usb.Device?
Yes, there is a EventHandler but no Event?
@ David@ Emrol - The Disconnected event is now part of the connected device itself: GHI.Usb.Device.Disconnected.
@ John - How “should” this be used? Not documented yet and 0 results on the forum.
I can start digging but i ported my main project code from 4.2 to 4.3 and have another 280 errors to look at… so if anyone has used this yet
using GHI.Usb.Host;
using GHI.Usb;
static Mouse mouse;
// Subscribe to USBH event.
Controller.DeviceConnected += Controller_DeviceConnected;
// Sleep forever
static void Controller_DeviceConnected(object sender, Controller.DeviceConnectedEventArgs e)
if (e.Device.Type == Device.DeviceType.Mouse)
Debug.Print("Mouse Connected");
mouse = new Mouse(e.Device);
mouse.CursorMoved += mouse_CursorMoved;
mouse.ButtonChanged += mouse_ButtonChanged;
static void mouse_CursorMoved(Mouse sender, Mouse.CursorMovedEventArgs e)
Debug.Print("(x, y) = (" + e.NewPosition.X + ", " +
e.NewPosition.Y + ")");
@ Gus, GHI.USB.Device does not exist. So Device.DeviceType.Mouse does not compile.
using GHI.Usb.Host;
using GHI.Usb;
static Mouse mouse;
// Sleep forever
e.Device.Disconnected += Device_Disconnected;
static void Device_Disconnected(Device sender, EventArgs e)
throw new System.NotImplementedException();
@ Mr. John Smith - you need both hardware and USB assemblies.
@ Gus, sorry it’s in the library GHI.Hardware
@ Gus - Thanks, at first it seems not logical why these where separated but i can see the logic behind it now, thanks again.
