We are excited to bring you another GHI Electronics exclusive feature. The new USB webcam support captures images on NETMF using EMX and ChipworkX. Images are simply placed into a standard “Bitmap” object. For saving images to media or transferring over networks, we’ve also added a method to convert the standard Bitmap object to a standard BMP file format.
There is also an experimental new WiFi driver in the SDK. This was only added for close partners and internal testing, public usage is not permitted yet.
Aha, good point that needs some history! Very recently, the USB organization released a USB class that is suitable for webcams. Before that, every manufacture had their own implementation and their own drivers. These cameras will not work on GHI’s NETMF devices as they are not “standardized”.
Now, how do you know if a camera is using USB class? Or it will work with GHI’s NETMF devices?
This is a tough question to answer.Generally, if a camera is advertised to run on windows/mac/linux then it is using USB class since these operating systems have the drivers built in, just like GHI’s NETMF devices.
To make this easier for our community, we will be offering a very low cost camera that is tested to work well. It should be up on the GHI’s catalog in couple days.
So basically the only thing needed is a driver less camera?
Found some on the web, which I think might work. They were cheap too, ~$10 (~7 euros), includes worldwide shipping.
I do not know if I am allowed to post a link, so let me know.
Excellent work indeed. I will try it today with my webcam which unfortunately did not work.
I will order the webcam specified before to test it out. ;D
