I have built a pcb with the 100 pin USBizi chip. I cannot get the board to respond to MFDeploy. I am reasonably sure I have the Mini B connector correct, but could someone verify?
Looking into the Mini B connector on my board, pin 1 is on the left and pin 5 is on the right. Pin 1 is Vbus, pin 2 is DM, pin 3 is DP, and pin 5 is ground. DP goes to the USBizi pin 29 and DM goes to pin 30.
All the voltages are at +3.29 volts. I have the exact usb interface as on the Panda board. (see attached jpg)
Can someone verify that this is correct. I am stumped by this simple device.
Are the USBizi100 (non-commercial)chips programmed and ready to develope code? I have physically checked this new board out, and I find all components, traces and voltages are correct.
The pnp transistor that is for turning voltage on to D+ of the mini usb connector is not turning on, thus no voltage on D+.
On the Panda, VBus/E36* pin 65 is used to sense the usb 5.0 volts and the processor turns on pin 64 USB_Con.
On the Mini, VBus/E36* pin 65 is used to sense the usb 5.0 volts and the processor turns on pin 64 USB_Con.
On the USBizi Dev-Sys 1.1 document dated 09/25/2008 on the GHI website, VBus goes to pin 40 and USB_Con2 goes to pin 48.
I used the Panda and the Mini pin configuration, but even though the VBus is at 5.0 volts USB_Con remain at 2.85 volts, never going low, thus not turning on the transistor and the voltage.
The USBizi 100 pin chip in use was purchased from GHI - designated USBizi100 (non-commercial).
Am I on the right pins? Are these chips ready to develop code, or is there a step I am missing?
