I get it working on some computers, but only on 32bit OS, is it possible that there is problem on 64bit systems and is there any solution to get it working on 64bit systems?
I do all of these steps, but in FEZ Config I cannot see Raptor as serial device, I use USB Client SP module, should I use USB serial module to see it as serial device?
You just need to connect a TTL USB-to-serial converter to the COM1 TX and RX pins on your Fez device. Then you can connect with MFDeploy or FezConfig over the serial port this converter presents, and access the debug messages there. Personally, I have several CP2102 converters sitting around as they are cheap and have drivers that donāt suck terribly (like some of the other cheap converters).
and beyond what @ David said, Iād also say you might have a code issueā¦ code can lock up the debug threads so theyāre not contactable from the debugger. But the simple checks are always the ones worth doing first, making sure the COM port is actually still visible (and still COM10) from Device Manager, and you donāt have another debugger attached
