Hi All,
I’ve been trying to make a little usb log class for writing data into a text file of sorts. I created the following class, which seems to be working fine, except that there is no actual data in the file. Even though it does create the file on the memstick.
class USBLog
private UsbHost usbHostModule;
private StorageDevice usbStorage;
private string logFileName = "";
private TextWriter logFile;
public bool DriveConnected = false;
public USBLog(UsbHost usbHost, string fileName)
usbHostModule = usbHost;
usbHostModule.DebugPrintEnabled = true;
// add events
usbHostModule.USBDriveConnected += new UsbHost.USBDriveConnectedEventHandler(usbHostModule_USBDriveConnected);
usbHostModule.USBDriveDisconnected += new UsbHost.USBDriveDisconnectedEventHandler(usbHostModule_USBDriveDisconnected);
logFileName = fileName;
// setup flags
void usbHostModule_USBDriveDisconnected(UsbHost sender)
try
// device is gone, but probably need to close anyways
logFile.Close();
catch (Exception Ex)
Debug.Print("Drive Disconnected: " + Ex.Message);
void usbHostModule_USBDriveConnected(UsbHost sender, StorageDevice storageDevice)
DriveConnected = true;
usbStorage = storageDevice;
// try to open file
Debug.Print( "Connected ! - Opening File" );
try
logFile = new StreamWriter(storageDevice.OpenWrite(logFileName));
Debug.Print("Error opening file: " + Ex.Message);
public void close()
logFile.Close();
public bool log(string msg)
if (!DriveConnected) return false;
Debug.Print("Writing Log Entry: " + msg);
try
logFile.WriteLine(msg);
logFile.Flush();
Debug.Print("Done");
Debug.Print("Error writing to log");
return false;
return true;
I tested this class with the following code:
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using Gadgeteer;
namespace USBLogger
public partial class Program
private USBLog log;
private bool firstTime = true;
usbHost.DebugPrintEnabled = true;
log = new USBLog(usbHost, "temp.log");
GT.Timer test= new GT.Timer(1000);
test.Tick += new GT.Timer.TickEventHandler(test_Tick);
test.Start();
void test_Tick(GT.Timer timer)
if (log.DriveConnected && firstTime )
log.log("Test 1");
log.log("Test 2");
log.log("Test 3");
log.log("Test 4");
log.log("Test 5");
firstTime = false;
and this is the output in Visual Studio
Program Started
Writing Log Entry: Test 1
Done
Writing Log Entry: Test 2
Done
Writing Log Entry: Test 3
Done
Writing Log Entry: Test 4
Done
Writing Log Entry: Test 5
Done
Like I said, the file gets created in the root of the memory stick, but it stays empty.
Any ideas? Or am I missing something?
