USBController sc = new USBController();
class USBController
IDriveProvider _driver;
StorageController _storageController;
public USBController()
var usbHostController = UsbHostController.GetDefault();
usbHostController.OnConnectionChangedEvent +=
UsbHostController_OnConnectionChangedEvent;
usbHostController.Enable();
public IDriveProvider Driver
get { return _driver; }
public StorageController Controller
get { return _storageController; }
private void UsbHostController_OnConnectionChangedEvent
(UsbHostController sender, DeviceConnectionEventArgs e)
Debug.WriteLine("e.Id = " + e.Id + " \n");
Debug.WriteLine("e.InterfaceIndex = " + e.InterfaceIndex + " \n");
Debug.WriteLine("e.PortNumber = " + e.PortNumber);
Debug.WriteLine("e.Type = " + ((object)(e.Type)).
ToString() + " \n");
Debug.WriteLine("e.VendorId = " + e.VendorId + " \n");
Debug.WriteLine("e.ProductId = " + e.ProductId + " \n");
switch (e.DeviceStatus)
case DeviceConnectionStatus.Connected:
switch (e.Type)
case BaseDevice.DeviceType.Keyboard:
var keyboard = new Keyboard(e.Id, e.InterfaceIndex);
keyboard.KeyUp += Keyboard_KeyUp;
keyboard.KeyDown += Keyboard_KeyDown;
break;
case BaseDevice.DeviceType.Mouse:
var mouse = new Mouse(e.Id, e.InterfaceIndex);
mouse.ButtonChanged += Mouse_ButtonChanged;
mouse.CursorMoved += Mouse_CursorMoved;
break;
case BaseDevice.DeviceType.Joystick:
var joystick = new Joystick(e.Id, e.InterfaceIndex);
joystick.CursorMoved += Joystick_CursorMoved;
joystick.HatSwitchPressed += Joystick_HatSwitchPressed;
joystick.ButtonChanged += Joystick_ButtonChanged;
break;
case BaseDevice.DeviceType.MassStorage:
_storageController = StorageController.FromName
(SC20260.StorageController.UsbHostMassStorage);
_driver = FileSystem.Mount(_storageController.Hdc);
var driveInfo = new DriveInfo(_driver.Name);
Debug.WriteLine("Free: " + driveInfo.TotalFreeSpace);
Debug.WriteLine("TotalSize: " + driveInfo.TotalSize);
Debug.WriteLine("VolumeLabel:" + driveInfo.VolumeLabel);
Debug.WriteLine("RootDirectory: " + driveInfo.RootDirectory);
Debug.WriteLine("DriveFormat: " + driveInfo.DriveFormat);
break;
default:
var rawDevice = new RawDevice(e.Id, e.InterfaceIndex, e.Type);
var devDesc = rawDevice.GetDeviceDescriptor();
var cfgDesc = rawDevice.GetConfigurationDescriptor(0);
var endpointData = new byte[7];
endpointData[0] = 7; //Length in bytes of this descriptor.
endpointData[1] = 5; //Descriptor type (endpoint).
endpointData[2] = 0x81; //Input endpoint address.
endpointData[3] = 3; //Transfer type is interrupt endpoint.
endpointData[4] = 8; //Max packet size LSB.
endpointData[5] = 0; //Max packet size MSB.
endpointData[6] = 10; //Polling interval.
var endpoint = new Endpoint(endpointData, 0);
var pipe = rawDevice.OpenPipe(endpoint);
pipe.TransferTimeout = 10;
var data = new byte[8];
var read = pipe.Transfer(data);
if (read > 0)
Debug.WriteLine("Raw Device has new data "
+ data[0] + ", " + data[1] + ", " + data[2] + ", " + data[3]);
else if (read == 0)
Debug.WriteLine("No new data");
Thread.Sleep(500);
break;
break;
case DeviceConnectionStatus.Disconnected:
Debug.WriteLine("Device Disconnected");
//Unmount filesystem if it was mounted.
break;
case DeviceConnectionStatus.Bad:
Debug.WriteLine("Bad Device");
break;
private static void Keyboard_KeyDown(Keyboard sender, Keyboard.KeyboardEventArgs args)
Debug.WriteLine("Key pressed: " + ((object)args.Which).ToString());
Debug.WriteLine("Key pressed ASCII: " +
((object)args.ASCII).ToString());
private static void Keyboard_KeyUp(Keyboard sender, Keyboard.KeyboardEventArgs args)
Debug.WriteLine("Key released: " + ((object)args.Which).ToString());
Debug.WriteLine("Key released ASCII: " + ((object)args.ASCII).ToString());
private static void Mouse_CursorMoved(Mouse sender, Mouse.CursorMovedEventArgs e)
Debug.WriteLine("Mouse moved to: " + e.NewPosition.X + ", " + e.NewPosition.Y);
private static void Mouse_ButtonChanged(Mouse sender, Mouse.ButtonChangedEventArgs args)
Debug.WriteLine("Mouse button changed: " + ((object)args.Which).ToString());
private static void Joystick_ButtonChanged(Joystick sender, Joystick.ButtonChangedEventArgs e)
Debug.WriteLine("Joystick button changed = " + ((object)(e.Which)).ToString());
private static void Joystick_HatSwitchPressed(Joystick sender, Joystick.HatSwitchPressedEventArgs e)
Debug.WriteLine("Joystick direction = " + ((object)(e.Direction)).ToString());
private static void Joystick_CursorMoved(Joystick sender, Joystick.CursorMovedEventArgs e)
Debug.WriteLine("Joystick.move = " + e.NewPosition.X + ", " + e.NewPosition.Y);
not sure how to identify what USB stick we’re using as it is a no brand device
