I’m brand new to the hardware world, so sorry if this is a dumb question.
I recently ordered a FEZ Reaper and a few components (buttons, sensors, etc.). I mistakenly thought it had an embedded USB port, but it doesn’t, so I have no way to power / program it. So I went to order a USB component (I tried USBSP-GM-330 and USBCDP-GM-280) but mouser.com no longer carries any. Ditto arrow.com and octopart.com.
What’s my best bet here? Are there other good sources for these parts? Or are there other compatible USB components I could use (that would be accessible to a noob like me)? Should I instead power the Reaper with a battery pack and use a serial port component for programming?
Thanks for the reply! Yeah, those are the parts I was looking for, but no one seems to stock them anymore (not mouser.com, not arrow.com, not octopart.com). Is there any other vendor you can suggest?
As far as i understand he want to use/program and power board with usb module and can not find to buy so i find and alternative on ebay and is very cheap since it have included pins for usb connection to mcu
Good suggestion, I may end up going with that. The downside is that it ships from China and will take several weeks to arrive. The upside is that it’s $1.
Dumb question, I see that the board has a USB port and a plug for power. Does that mean it will not use the USB port itself for power? In which case, I need to buy an AC adapter?
Ah, didn’t know about robotshop.com, thanks for the pointer! This would supply power, but I would also need some way to program the SoC, right? Like a module with an RS232 port?
You need a red board for powering and programming a module. Usually you would use a USB DP or USB SP module. The difference is the SP module only powers via the USB socket, and the DP also allows a voltage input of up to 9-12V. DP means dual power.
The battery module, which is red, provides a USB client interface, which is what is needed to program the board. It is all that you need to program. Primary programming mode is via USB.
I am in the Princeton NJ area. If you need a power module fast, I can lend one to you.
@Gus/@Gary, looks like the most important part of the Gadgeteer inventory is tapped out. Any chance you’ll do an injection on DP or SP modules to help the depleting mainboard stock ?
