Hello,
Is a usb client with the fez panda 1 possible without a shield.
There is no difference between panda 1 and 2 regarding the USB port; it can be either configured as a client OR host usb port.
The USB port on the panda actually is a USB client port.
You can choose to transform it into a USB host port (but not both at the same time, for that you would need a Fez domino):
http://ghielectronics.blogspot.com/2011/03/usb-host-support-is-added-on-fez-panda.html
Have Fun
So if I want to develop a program that use the fez as a usb client but for debugging I can use this
[url]http://www.ghielectronics.com/catalog/product/266[/url]
Yes, or any other USB to serial TTL cable !
Just connect the MOD pin to GND (which will tell the panda to use serial debugging instead of USB)
Use it with eblock shield and it will be all a peice of cake
