URM37 Ultrasonic Sensor and FEZ Domino
Hello all! need help!
Sensor: [url]Fermion: URM37 Ultrasonic Sensor for Arduino / Raspberry Pi - DFRobot
How to connect URM37 range sensor to Domino for using Serial mode?
I need some sample C# source code to getting distance value from sensor via serial.
thank u very much!
I couldn’t find its manual but the description says it has a TTL output…you need to connect that to any of the UART RX pins on FEZ
Yes , the manual link is broken ::slight_smile:
But I found it here
[url]http://www.dfrobot.com/wiki/index.php?title=URM37_V3.2_Ultrasonic_Sensor_Manual(SKU:SEN0001)[/url]
ok, thank u.
There are sensor pins:
1 +VCC
2 GND
3 RST
4 PWM
5 MOTO
6 COMP/TRIG
7 COMP
8 TRIG
9 PWR_ON - Enable pin – WHAT IS IT?
8 RXD
9 TXD
So, I connected:
Domino <–> Sensor
UEXT4 <–> 8
UEXT3 <–> 9
GND <–> 2
+3.3 <–> 1
Correct?
Code:
SerialPort sensor = new SerialPort(“COM2”, 9600);
sensor.Open();
sensor.Read(…) – waiting…and nothing?
what do i do wrong? thank u!
Did you set the jumpers in ttl mode?
yes. TTL mode is on.
And I connected sensor pin7 to Di3.
My code now:
SerialPort urm = new SerialPort("COM2", 9600);
urm.Open();
OutputPort nic = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di3, false);
nic.Write(true);
Thread.Sleep(200);
byte[] cmd = { 0x22, 0x00, 0x00, 0x22}; //distance measure command
urm.Write(cmd, 0, 4);
Thread.Sleep(75);
    byte[] buf = new byte[4];
    urm.Read(buf, 0, 4); <--- wait..and wait..
not working! please help!
Hi retmas ,
you have to wire the sensor to the following pins
Domino <–> Sensor
UEXT4 (RXD) <–> 9 (TXD) rxd/txd crossed
UEXT3 (TXD) <–> 8 (RXD)
VCC or Port Pin <–> 7 (PWR_ON) the module is activated with a high level
GND <–> 2
VCC <–> 1 have in mind the module needs 5V
thank you. i will try it.
Success. It’s working…
My simple class for URM37 sensor:
    Copyright (c) 2011 Dmitry Golubkov. All rights reserved.
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
Module Name:
	FEZ.Sensors.URM37
Abstract:
    Implementation basic functions of URM37 V3.2 Ultrasonic Sensor for using with FEZ Domino.
    TTL serial interface connection:
        +VCC (Domino) <- Pin 1 (URM37)
        GND (Domino) <- Pin 2 (URM37)
        Pin12 (Domino) <- Pin 7 (URM37)
        UEXT4 (RX, COM2) (Domino) <- Pin 9 (URM37)
        UEXT3 (TX, COM2) (Domino) <- Pin 8 (URM37)
    Units: distance - cm, temperature - Celsius
using System.IO.Ports;
namespace FEZ.Sensors
    class URM37: IDisposable
        private SerialPort _sensorPort;
        private OutputPort _enablePin;
        private byte[] _getDistanceCommand = new byte[] { 0x22, 0x00, 0x00, 0x22 };
        private byte[] _getTemperatureCommand = new byte[] { 0x11, 0x00, 0x00, 0x11 };
        public void Dispose()
            _sensorPort.Dispose();
        public URM37(string serialPortName, Cpu.Pin EnablePin)
            _sensorPort = new SerialPort(serialPortName, 9600);
            // open TTL connection
            _sensorPort.Open();
            _enablePin = new OutputPort(EnablePin, false);
            // enable the sensor
            _enablePin.Write(true);
        public int GetDistance()
            _sensorPort.Write(_getDistanceCommand, 0, _getDistanceCommand.Length);
            byte[] resultBuffer = new byte[4];
            _sensorPort.Read(resultBuffer, 0, resultBuffer.Length);
            byte commandByte = resultBuffer[0];
            byte highByte = resultBuffer[1];
            byte lowByte = resultBuffer[2];
            byte sumByte = resultBuffer[3];
            int value = 0;
            if (highByte == 0xff)
                return 0;
                value = highByte * 0xff + lowByte;
            return value;
        public double GetTemperature()
            _sensorPort.Write(_getTemperatureCommand, 0, _getTemperatureCommand.Length);
            double value = 0;
            if (highByte >= 0xf0)
                value = (double)(((double)highByte - 0xf0) * 0xff + (double)lowByte) / 10;
                value = (double)((double)highByte * 0xff + (double)lowByte) / 10;
            return value;
Hi retmas ,
nice work :clap:
Now you can post it on fezzer.com
cool. how to post it to fezzer.com?
After logging in to Fezzer.com click on “Create” in the main navigation at the top. After that just fill in the information.
