Updating XAML controls from a button press throws a WRONG THREAD error
Hi All;
I’m working on a UI project, and if I update the controls on my screen using a button on the screen, or a timer, it works fine, but the same function, when called from a button press, throws an RPC_E_WRONG_THREAD error:
txtMoisture.Text = Math.Floor(reading).ToString() + "%";
txtStatus.Text = StatusMessage;
Those two lines are the guilty party, but how do I get them into the UI thread?
Usually it is done through Dispatcher:
if (!Dispatcher.CheckAccess())
   Dispatcher.BeginInvoke(...);
That gives me somewhere to start googling, thanks!
I think you need to use BeginInvoke()
  private delegate void SetLabelTextDelegate(int number);
   private void SetLabelText(int number)
      // label.Text = number.ToString();
      // Do NOT do this, as we are on a different thread.
      // Check if we need to call BeginInvoke.
      if (this.InvokeRequired)
         // Pass the same function to BeginInvoke,
         // but the call would come on the correct
         // thread and InvokeRequired will be false.
         this.BeginInvoke(new SetLabelTextDelegate(SetLabelText),
                                          new object[] {number});
         return;
What I found here seems to be working:
var IGNORE_ME = this.Dispatcher.RunAsync(Windows.UI.Core.CoreDispatcherPriority.Normal, () =>
I should have refreshed before posting, lol
@ mtylerjr - NP, glad for the help.
You don’t need the “var IGNORE_ME =”, so you can just remove that.
Also, I recommend checking access unless you’re positive this code will only be called from a place that requires dispatching. This runs asynchronously and does take a bit more time than a regular call.
Pete
Thanks Pete, I started without it, but when it put green underlines around the code for not catching the return I felt compelled to obey VS.
