Updating Spider with 4.2 Preview Release
I just tried to update my Spider with the preview 4.2 SDK released yesterday and I am having a problem.
I found the Spider Updater in the “C:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Firmware Update” directory. It was compiled June 15, 2012.
When I opened it, the TinyBooter and Firmware textboxes were pointing at the 4.1 files instead of the 4.2 files.
I changed the TinyBooter textbox to point at the 4.2 tinyboot file, and then selected the two firmware files in the 4.2 firmware directory.
When I hit the next button, I got a message that the sig file was missing. I verified that there was a sig file in the 4.1 firmware directory, but not the 4.2.
I noticed that there are three copies of the FEZSpiderMianboardUpdater.exe in the distribution, each with different compilation dates. I don’t know if they
are actually from different code bases.
At a minimum, the updater under the 4.2 directory should point at 4.2 files instead of 4.1 files. The sig issue is still a mystery to me.
What am I missing?
BTW, I uninstalled all of the GHI and MS SDK stuff before installing the preview;.
Thanks for feedback. Will fix in next release.
Is the sig file missing?
I do not think it is required with this release. If updater doesn’t work them use the old manual update way.
I think the guys should review all updaters.
HI,
I have the same problem.
Some work-arround to skip sig file ?
I Use this Updater
C:\Program Files\GHI Electronics\GHI Premium NETMF v4.2 SDK\Firmware Update\FEZSpiderMainboardUpdater.exe
Thanks in advance,
I tried all those 3 updaters:
FEZSpiderMainboardUpdater.exe 2012-06-15 12:06 1.871 KB Firmware Update (C:\Program Files\GHI Electronics\GHI Premium NETMF v4.2 SDK)
FEZSpiderMainboardUpdater.exe 2012-02-16 11:04 Application 1,869 KB Firmware Update (C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK)
FEZSpiderMainboardUpdater.exe 2012-01-12 08:16 Application 1.871 KB Firmware Update (C:\Program Files\GHI Electronics\GHI .NET Gadgeteer SDK)
See firmware update on wiki to see how to do if manual. We fix this Monday.
Please see note added to this thread http://www.tinyclr.com/forum/topic?id=7457
For EMX Updater using 4.2 SDK there are only two files but it requires Three so what should do for third file???
@ Sid -
The issue was resolved in the Beta that was released June 22, 2012.
Welcome to the forums!
