Hello, I just developed a PCB board that is made up of a FEZ domino and a Texas instruments USB hub. The code worked fine on the old domino board I had, however when I got these new USBizi 144 chips on my board I had to update the firmware with the newer versions.
Since the firmware is newer it has changed and my basic commands are reporting errors. For instance this command now gives me an error.
LED = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, true); //Define LED as output pin, used for debugging button interrupts
The error produced is :
Error 8 The name ‘FEZ_Pin’ does not exist in the current context
My code has an error anywhere that I use the command "FEZ_Pin’, which is pretty much everywhere =)
Is there a silly mistake I have made installing the new firmware that can lead to this error?
Best Regards,
Aaron
