Dear All:
As a new user of FEZ Cerberus, I tried to build my first application following the instructions without any problem. In order to experience the hardware, I tried another example that links joystick to a LED7R. While compiling and deploying the code, I got following error messages:
Create TS.
Loading start at 8036fc8, end 804b620
Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)
Assembly: Microsoft.SPOT.Net (4.2.0.0)Assembly: System (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.Joystick (1.1.1.0)Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0)Attaching deployed file.
Assembly: System.Http (4.2.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (1.1.2.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.LED7R (1.1.1.0)Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.4.0)Attaching deployed file.
Assembly: GadgeteerApp1 (1.0.0.0)Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)Attaching deployed file.
Assembly: System.IO (4.2.0.0)Resolving.
Resolve: unknown type: AnalogOutputChannel
Error: ff000000
Waiting for debug commands…
The program ‘[10] Micro Framework application: Managed’ has exited with code 0 (0x0).
I have also tried the same example on different computers, and got the same results.
Could someone please provide any suggestion for the problem?
My software configuration:
WinXP SP3, Microsoft Visual C# 2010 Express, .NET Microframework SDK 4.2 (QFE2), and GHI NETMF v4.2 and .NET Gadgeteer Package 2013-02-14.
Code I tried to compile and deploy:
using System.Collections;
//using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
joystick.JoystickPressed += new Joystick.JoystickEventHandler(joystick_JoystickPressed);
joystick.JoystickReleased += new Joystick.JoystickEventHandler(joystick_JoystickReleased);
void joystick_JoystickReleased(Joystick sender, Joystick.JoystickState state)
Debug.Print("Joystick Released");
led7r.TurnLightOff(7);
void joystick_JoystickPressed(Joystick sender, Joystick.JoystickState state)
Debug.Print("Joystick Pressed");
led7r.TurnLightOn(7);
James Tsai
