@ Iggmoe - that’s post modern Briton for you…
This looks fascinating, will definietly give that a look! many thanks!
Yes I agree, I would have liked a bigger budget and freedom to choose my own hardware, but ah well, I guess industry will be much the same
You are welcome!
@ Justin - The tool is perfect for PID tuning
@ Architect - i think you have stumbled on a cunning plan…so cunning you could pin a tail on it and call it a weasel
Hey guys! I m so nearly there! I have implemented an FFT program and adapted it to my needs, all that remains is to feed my analogue input into the program!
But, the digital input is 32 Bit signed integer, whilst the program only accepts a double precision floating point number (the operation double needs to be applied to it)
What is the easiest way to convert the variable scope as listed in this line? “AnalogInput scope = new AnalogInput((Cpu.AnalogChannel)Cpu.AnalogChannel.ANALOG_0, 15);”
private void DoChart()
{double Fs = 11025; // 11kHz Sampling frequency
double TimeStep = 1000.0 / Fs; // time step in mS
double HzPerBin = Fs / N;
double Delta_F = Fs / N; // 11025/8192 = 1.34 Hz/bin
double f1 = scope; // Sinusoid frequencies
double f2 = 0; // Sinusoid frequencies
double f3 = 0; // Sinusoid frequencies
double Theta1 = 2 * Pi * f1 / Fs; // Normalized frequency 1
double Theta2 = 2 * Pi * f2 / Fs; // Normalized frequency 2
double Theta3 = 2 * Pi * f3 / Fs; // Normalized frequency 3
double A1 = 1;
double A2 = 0.5;
double A3 = 0.1;
double p1 = 0;
double p2 = 0.2 * Pi;
double p3 = 0.7 * Pi;
double Noise;
double NoiseLevel = 0.1;
Convert to what?
a “double precision floating point number” according to visual studio. Having perused the msdn website, im fairly certain that is the correct term, i could however be horribly mistaken!
You need to read from the scope. You variable scope is an object. It has methods. You need to call one of its Read methods.
Im trying to achieve that, its not going well im afraid
I found this on msdn, but it doesnt seem to work for me, the same error message persists saying
"Error 1 Cannot implicitly convert type ‘Microsoft.SPOT.Hardware.AnalogInput’ to ‘double’ "
public void ConvertDoubleInt(double doubleVal) {
int intVal = 0;
// Double to int conversion can overflow.
try {
intVal = System.Convert.ToInt32(doubleVal);
System.Console.WriteLine("{0} as an int is: {1}",
doubleVal, intVal);
catch (System.OverflowException) {
"Overflow in double-to-int conversion.");
// Int to double conversion cannot overflow.
doubleVal = System.Convert.ToDouble(intVal);
System.Console.WriteLine("{0} as a double is: {1}",
intVal, doubleVal);
Use cast.
for example:
double d = 4.9;
int i = (int)d;
Based on this error it looks like you are trying to treat an instance of an AnalogInput class as a double.
I think I see the problem from your earlier post
AnalogInput scope = new AnalogInput((Cpu.AnalogChannel)Cpu.AnalogChannel.ANALOG_0, 15); <------ Scope is an AnalogInput
double f1 = scope; // Sinusoid frequencies <----------------------- Here you assign scope, the AnalogInput to a double, you need call Read
double A1 = 1;
double A2 = 0.5;
double A3 = 0.1;
double p1 = 0;
double Noise;
it says “A field initializer cannot reference the non-static field, method, or property”
is this the method applied to convert 32 bit signed integer to floating point(double precision)?
and sure, ill paste it below
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using GHI.Premium.Hardware;
namespace TransformDemo
public partial class Form1 : Form
private System.Windows.Forms.DataGrid DataGrid1;
private Windale.Transform.TransformNET transformNET1;
private int Count = 0;
private int CountMax;
private int N; // Number of samples
private int Ndisplay;
private int N2;
// DataGrid Variables
// Create a new DataTable.
private DataTable dTable = new DataTable("DTable");
// Create column and row variables to be added to the DataTable
private DataColumn dtCol;
private DataRow dtRow;
public Form1()
InitializeComponent();
transformNET1 = new Windale.Transform.TransformNET();
private void Form1_Load(object sender, System.EventArgs e)
// Set ThreadMode Property
// This property determines whether subsequent methods
// will operate within their own thread within the component.
// This method makes it possible for component methods to be
// performed in the fastest possible time, however it also
// demands that the calling application creates and manages
// their own threads within which the component methods are called.
// For now we let it run in the main application without extra threading.
// To ensure the GUI responds, this should be done in a thread
// or else set ThreadMode = true (default).
//transformNET1.ThreadMode = false;
N = 16 * 1024; // Number of samples
Ndisplay = N / 2;
N2 = N / 2;
MakeTable(N2);
CountMax = 1;
DoChart();
private void MakeTable(long N)
// Make table N rows long
// Add column to the DataTable
dtCol = new DataColumn();
dtCol.ColumnName = "No";
dtCol.AutoIncrement = true;
dtCol.Caption = "No";
dtCol.ReadOnly = true;
dtCol.Unique = true;
dTable.Columns.Add(dtCol);
dtCol.ColumnName = "X (V)";
dtCol.AutoIncrement = false;
dtCol.Caption = "X (V)";
dtCol.ReadOnly = false;
dtCol.Unique = false;
dtCol.ColumnName = "Gain (dBV)";
dtCol.Caption = "Gain (dBV)";
dtCol.ColumnName = "Spectrum (kHz)";
dtCol.Caption = "Spectrum (kHz)";
// Add rows to the table
dtRow = dTable.NewRow();
dtRow["No"] = 0;
dTable.Rows.Add(dtRow);
long i = 0;
for (i = 1; i < N; i++)
DataGrid1.DataSource = dTable;
ClearTable();
private void ClearTable()
int i = 0;
int j = 0;
int Nrows = 0;
int Ncols = 0;
Nrows = dTable.Rows.Count;
Ncols = dTable.Columns.Count;
for (i = 0; i < Nrows; i++)
dtRow = dTable.Rows[i];
for (j = 1; j < Ncols; j++)
dtRow[j] = "";
private void btnStop_Click(object sender, EventArgs e)
btnStart.Enabled = true;
btnStop.Enabled = false;
Count = CountMax; // stop the Chart updating
private void btnStart_Click(object sender, EventArgs e)
btnStart.Enabled = false;
btnStop.Enabled = true;
// This should be done in a thread .. for demo just run here in GUI
CountMax = 200;
DoChart();
double scope2 = 4.9;
int i = (int)scope2;
int i;
double Pi = 3.14159;
double [] X = new double[N];
double [] Time = new double[N];
double [] Gain = new double[N2];
double [] Freq = new double[N2];
double [] PeakAmplitude = new double[N];
double [] PeakPhase = new double[N];
double [] PeakFrequencies = new double[N];
double [] Phase = new double[N];
// Input Signal Parameters
double A1 = 1;
double A2 = 0.5;
double A3 = 0.1;
double p1 = 0;
double Noise;
Random random = new Random();
// Parameters
// Parameters
int AmplitudeType = 9; // MagnitudedBVNormDefMax2 dBV(Norm) =
// dbV normalized to a DefMax maximum peak output.
int WindowType = 0; // 0 = No window, 2 = Hanning
int WindowOptions1 = 1;
double Rload = 50;
double DefMax = 10.0;
double[] Parms = { AmplitudeType, Fs, WindowType, WindowOptions1, 0, 0, 0, Rload, DefMax };
do
// Get input signal
double TotalTime = 0;
for (i = 0; i < N; i++)
Noise = NoiseLevel * (float)(random.NextDouble() * 2.0 - 1);
X[i] = A1 * System.Math.Cos(Theta1 * i + p1)
+ A2 * System.Math.Cos(Theta2 * i + p2)
+ A3 * System.Math.Cos(Theta3 * i + p3)
+ Noise;
Time[i] = TotalTime;
TotalTime += TimeStep;
// Estimate spectrum using FFT
transformNET1.Spectrum(ref X, ref Gain, ref Phase, ref Freq, ref PeakAmplitude, ref PeakPhase, ref PeakFrequencies, ref Parms);
for (i = 0; i < N2; i++)
Freq[i] = Freq[i] / 1000.0;
// Fill grid with data
if (Count == 0)
dtRow["X (V)"] = X[i].ToString("#.###");
dtRow["Gain (dBV)"] = Gain[i].ToString("#.###");
dtRow["Spectrum (kHz)"] = Freq[i].ToString("#.###");
// Display peak frequencies
textBox1.Text = "Peak Freq: " + PeakFrequencies[0].ToString("####") + "Hz" + " @ " + PeakAmplitude[0].ToString("0.00") + "dBV";
//textBox2.Text = textBox2.Text + ", " + PeakFrequencies[1].ToString("0:###.##") + "Hz" + " @ " + PeakAmplitude[1].ToString("0:###.##") + "dBV";
// Clear display
try
chart1.Series["Spectrum"].Points.Clear();
chart2.Series["Signal"].Points.Clear();
catch
chart1.ChartAreas["ChartArea1"].AxisX.Minimum = 0;
chart1.ChartAreas["ChartArea1"].AxisY.Minimum = -80;
chart2.ChartAreas["ChartArea1"].AxisX.Minimum = 0;
chart2.ChartAreas["ChartArea1"].AxisX.Maximum = 10;
chart2.ChartAreas["ChartArea1"].AxisY.Minimum = -2;
chart2.ChartAreas["ChartArea1"].AxisY.Maximum = 2;
// Populate the Chart with current data
for (int ic = 0; ic < Ndisplay; ic++)
chart1.Series["Spectrum"].Points.AddXY(Freq[ic], Gain[ic]);
for (int ic = 0; ic < Ndisplay/40; ic++)
chart2.Series["Signal"].Points.AddXY(Time[ic], X[ic]);
chart1.Invalidate();
chart2.Invalidate();
Count++;
} while (Count < CountMax);
Count = 0; // Reset
As I mentioned above you need to use one of the Read methods:
scope.Read()
Edit1: Can you please use code tags
Edit2: Quick tutorial on how to use AnalogInput:
Hey guys, when trying to read from the analog input, I get this message, even with very simple code
An unhandled exception of type ‘System.ArgumentException’ occurred in Microsoft.SPOT.Hardware.dll
What am i doing wrong? I’ve referenced everything i think
AnalogInput lightSensor = new AnalogInput((Cpu.AnalogChannel)Cpu.AnalogChannel.ANALOG_1,
10);
double lightSensorReading = 0;
lightSensorReading = lightSensor.Read();
Debug.Print(lightSensorReading.ToString());
Thread.Sleep(500);
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
Ah i see! ive edited the post
@ ks09aao - What line gives you the exception?
The error is gone now that i changed the analogin command, Im not sure why though!
Now when i debug my program it says “the debugging target is not an initialized state, rebooting”, why is this? the print commands do not come out in the debug window either, the debugging closes briefly after starting
using GHI.OSHW.Hardware;
AnalogInput lightSensor = new AnalogInput(FEZCerbuino.Pin.AnalogIn.A1);
Thread.Sleep(500);
void programStarted()
Oh i see, so the fact that I get no output is more program related, I need to change how I manipulate the output
Is there some kind of loop I can use that would sample the amplitude every second and print it to the debug window?
Ahhh sorry daft question, yes your quite right!
This is the output from the debug window, the lines “ERROR!!! Firmware version does not match managed code version!!!” and “Cannot find any entrypoint!” are cuase for concern?
Create TS.
Loading start at 8059dcc, end 807ac80
Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0)Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.4.0)***********************************************************************
* ERROR!!!! Firmware version does not match managed code version!!!! *
* Invalid native checksum: GHI.OSHW.Hardware 0xEE697492!=0x52D307E9 *
Resolving.
Ready.
Done.
Waiting for debug commands...
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
The program '[21] Micro Framework application: Managed' has exited with code 0 (0x0).
