anytime buddy
please do keep us in the loop about your progress, we love to hear what you guys are doing
Cheers,
Jay.
anytime buddy
Cheers,
Jay.
@ Jay Jay - Inching closer, they killed DeviceInfo.GetDeviceID() == DeviceID.FEZ_CERB in 4.3 from the looks of it, using your docs link I see an enumerator for DeviceType:
But I canβt see where it is actually made available.
@ Squeebee - In your linked page it says: βTo get the system model type use Microsoft.SPOT.Hardware.SystemInfo.SystemID.Modelβ :
@ iamin - Whoops, thanks!
@ Squeebee - as @ iamin said you would use it as follow:
if(Microsoft.SPOT.Hardware.SystemInfo.SystemID.Model == DeviceType.CerbFamily){
//create an empty byte array to hold the unique Deviceid of STM32F4
var deviceid = new byte[12];
//read the address where the unique id is burned.
#if MF_FRAMEWORK_VERSION_V4_2
GHI.OSHW.Hardware.LowLevel.AddressSpace.Read((uint)0x1FFF7A10, deviceid, 0, 12);
#else
//this is for framework 4.3 and higher
GHI.Processor.AddressSpace.Read((uint)0x1FFF7A10, deviceid, 0, 12);
#endif
@ Jay Jay - I got mine working by with the following:
getID()
//GET A MAC FOR THIS DEVICE, USED TO CORRELATE DATA IN THE DB
//check if this is a Cerb Family board
if ( Microsoft.SPOT.Hardware.SystemInfo.SystemID.Model == (byte)GHI.Processor.DeviceType.CerbFamily )
return GenerateUniqueMacAddr(deviceid);
return null;
So would this also be an acceptable way to get a Guid (UUID) that uniquely identifies each board ?
private string getID()
//GET A UUID FOR THIS DEVICE, USED TO CORRELATE DATA IN THE DB
if (Microsoft.SPOT.Hardware.SystemInfo.SystemID.Model == (byte)GHI.Processor.DeviceType.CerbFamily)
var deviceid = new byte[16];
GHI.Processor.AddressSpace.Read((uint)0x1FFF7A10, deviceid, 0, 16);
return new Guid(deviceid).ToString();
return null;
@ DanW - I like that! Works for me! I was even able to keep the AddressSpace.Read at 12 bytes instead of 16 and still got a GUID out of it.
@ DanW - Just to add to this, I tried the following on a new Panda III board, the G80 chip, and it seems to work on it too.
if (SystemInfo.SystemID.Model == (byte)GHI.Processor.DeviceType.G80)
That produces this output: Device UID: 004c001e-5113-3334-3436-3532c0fc00c0
