We have met a problem which is probably related to memory leak, but it could also be that our application is getting quite large.
The app is currently running on the Embedded Master module which should have 8 MB of RAM, but the GC reports a total of 5242632 bytes (about 5MB) Where does the remaining 3MB go ?
Will moving all strings (like in the exemple below) to resource file reduce total RAM usage ?
Log.Info("This is a string, but is it taking up RAM or is it stored in Flash ?");
The problem seems to be “SZARRAY” which grows until we break. What kind of data/objects go to type 13 (SZARRAY) ? Need input to help me debug my code…
Why does the allocation fail (Failed allocation for 53 blocks, 636 bytes), we still have more than 636 bytes available…
Does there exists some way to query the GC or other system objects about total memory usage during runtime, and is there a way to debug/show the total objects of each type ?
GC: 638msec 5218320 bytes used, 24312 bytes available <= Giving a total of 5242632 bytes (!?)
Type 0F (STRING ): 110772 bytes
Type 11 (CLASS ): 1451760 bytes
Type 12 (VALUETYPE ): 4632 bytes
Type 13 (SZARRAY ): 2829900 bytes
Type 15 (FREEBLOCK ): 24312 bytes
Type 17 (ASSEMBLY ): 71484 bytes
Type 18 (WEAKCLASS ): 432 bytes
Type 19 (REFLECTION ): 204 bytes
Type 1B (DELEGATE_HEAD ): 7200 bytes
Type 1C (DELEGATELIST_HEAD ): 120 bytes
Type 1D (OBJECT_TO_EVENT ): 696 bytes
Type 1E (BINARY_BLOB_HEAD ): 481728 bytes
Type 1F (THREAD ): 4224 bytes
Type 20 (SUBTHREAD ): 432 bytes
Type 21 (STACK_FRAME ): 4752 bytes
Type 22 (TIMER_HEAD ): 144 bytes
Type 26 (WAIT_FOR_OBJECT_HEAD): 48 bytes
Type 27 (FINALIZER_HEAD ): 242568 bytes
Type 31 (IO_PORT ): 468 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 6684 bytes
All my “strings” as in my example is actually taking RAM when running, even if the class is not initialized.
Many such strings will add up to a large amount of RAM.
Moving the strings to Resource file will only use RAM when i use them, after that they will be disposed, and total memory usage will be less ?
Just to be 100% sure before I modify 1000+ of code lines…
I would really like to have some way to traverse the allocated objects to see what they are to understand more about what thay are and who owns them (or not…).
I am afraid I am having a memory leak, and it’s difficult to even have an idea where the error is since tha app is so big.
Yep I told you, even your HUGE application is using only about 1MB of RAM So do not worry about strings or about “saving memory” as you have plenty of memory. You still got 4MB free to go.
Ok, so I do [italic]think[/italic] I have found out of the problem…
When I added a “console” command to run GC and report the free memory after a GC (both to serial console and to the Debug window in VS) it seems like there is no more memory leak anymore…
I have done some changes to the code as well to minimize the potential problem you can get if you dont unhook your event handlers.
I have also stopped using the internal DNS and WebService functions, and are using a special class for socket connections that I have implemented to get around the bug that the Connect() may NEVER return if the ACK/NACK sequence is not correct (in case of GPRS with packet loss or Firewalls).
I got a feedback from Colin Miller at Microsoft informing me this:
[quote]Call Dispose on all types that support it (eg bitmap)
Dont write any busy loops (tight looping without releasing resources. There was a bug in 4.1 where if there is always an active thread in the managed app, objects with Dispose or a finalize will not get GCd. You want to avoid busy loops in any event.[/quote]
This may be the main source of my problem, busy loops in threads - or busy socket connections on threads that I try to kill with Thread.Abort() after a failed Socket.Connect.
