Im currently trying to send a Bitmap that is converted into a byte array over UDP Client (Over WiFi).
Although it is big only 8192 bytes are sent - always.
Is there a way to send the whole thing ? Or a mechanisim to divide this array and send it in chunks ?
Have you any suggestions ?
Also:
Is GetBitmap() - which returns an array of bytes from a bitmap - efficient ?
Are you planing of adding an GetBytess() function to call from the webcamera ?
It means - is there a better way to do this or was this optimized ? Plus will they give a GetBitmapInBytes() function specifically for calling on webcam ( like you said the conversion takes a little time ).
The thing that bothers me the most- i checked the functions return value and it did return the data that were to send ( i did a loop to ensure that all of them are sent and it just went into that loop once and did return the amount of datat that i wanted to send.
The problem is that on the other side i received only 8192 bytes - i did a loop there to to check the availability -receive the data - sleep for 100 msec and check it again. After 100 msec there where no more available bytes.
