UCM Dev Board
I have a UCM Dev Board with a UC5550
I know that UCM550 will not be compatible with TinyCLR 2.0 but can I still use my Dev board with the new upcoming module ?
Mostly yes
What are the major incompatibilities ?
SPI1 bus and other minor pins are incompatible. Power/USB/Ethernet/display and other major features are compatible. You can easily check the G400 datasheet to see what pins are there.
http://files.ghielectronics.com/downloads/Documents/Datasheets/G400S%20and%20G400D%20Datasheet.pdf
