Can someone confirm that the FEZ Domino and Mini can reliably support UART speeds of 921.6kbps? I wanted to interface with the board via a Blutetooth module using SPP connected via TTL.
Yes this baud rate is supported
Sorry if I am just not doing somethig obvious or did not ask the earlier question with enough background information, but I can’t get rates any higher than 115200. When I open the port I get an exception. I also can’t use any non-standard baud rates without the same result.
The call is simply
SerialPort UART = new SerialPort(“COM1”, 230400,Parity.Even);
-AP
Are you using the emulator or FEZ?
Any baud rate, even non standard ones, should work
The problem could be in parity. I am not sure if parity is supported so try no parity first
