Good evening, I bought some ualfat modules last year and intend to use to them on a project now. However, I just ran into a big problem:
whenever I try to read a file that is more than 1kbyte long, ualfat starts to get lost. It starts reading the bytes wrongly after the 1046th approximately. is this a common issue?? I really need thoughts. It really seems like a messed up stack pointer in the firmware..
I believe I'm doing everything else right, since I can read the first 1k data...
If someone could share a piece of actual code where ualfat reads data from SPI I'd appreciate.
thank you,
Saul Andrade
