I had them defined just like James’s example. Then cross between PWM1 and PWM2 is due to the circuit board layout. This is a custom industrial controller based on the 100 pin module GHI sells and defined as a Panda II for pinout and software purposes. The full code is here:
using System.IO.Ports;
namespace IndustrialIO
/// <summary>
/// Shows if there is data available
/// </summary>
static bool isData = false;
/// <summary>
/// Stores serial buffer data
/// </summary>
static string bufferString = String.Empty;
/// <summary>
/// Store PWM duty cycles
/// </summary>
static int pwm1Duty = 100;
static int pwm2Duty = 100;
/// <summary>
/// Stores Emergency Trip
/// </summary>
static bool emergencyBit = false;
/// <summary>
/// Sets up COM1 on the FEZ mini as the PC communication port
/// </summary>
static SerialPort COM1 = new SerialPort("COM1", 115000);
/// <summary>
/// Stores I2C device
/// </summary>
static I2CDevice myI2C;
/// <summary>
/// Create ADS1115 A/D Converter configuration
/// </summary>
static I2CDevice.Configuration ADS1115 = new I2CDevice.Configuration(0x48, 400);
/// <summary>
/// Set up Input Ports
/// </summary>
public static InputPort LDR = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.LDR, false, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
public static InputPort DIN1 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.An0, false, Port.ResistorMode.PullDown);
public static InputPort DIN2 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.An1, false, Port.ResistorMode.PullDown);
public static InputPort DIN3 = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.An2, false, Port.ResistorMode.PullDown, Port.InterruptMode.InterruptEdgeHigh);
public static InputPort DIN4 = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.Di12, false, Port.ResistorMode.PullDown, Port.InterruptMode.InterruptEdgeHigh);
public static InputPort DIN5 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.Di11, false, Port.ResistorMode.PullDown);
public static InputPort DIN6 = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.Di13, false, Port.ResistorMode.PullDown, Port.InterruptMode.InterruptEdgeBoth);
public static InputPort DIN7 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.Di5, false, Port.ResistorMode.PullDown);
public static InputPort DIN8 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.Di6, false, Port.ResistorMode.PullDown);
public static InputPort[] inputPorts = new InputPort[] {DIN1,DIN2,DIN3,DIN4,DIN5,DIN6,DIN7,DIN8};
/// <summary>
/// Set up output ports
/// </summary>
public static OutputPort DOUT1 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di21, false);
public static OutputPort DOUT2 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di20, false);
public static OutputPort DOUT3 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di23, false);
public static OutputPort DOUT4 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di22, false);
public static OutputPort DOUT5 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di25, false);
public static OutputPort DOUT6 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di24, false);
public static OutputPort DOUT7 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di27, false);
public static OutputPort DOUT8 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di26, false);
public static OutputPort LED = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, false);
public static OutputPort[] outputPorts = new OutputPort[] { DOUT1, DOUT2, DOUT3, DOUT4, DOUT5, DOUT6, DOUT7, DOUT8 };
/// <summary>
/// Sets up PWM pins
/// </summary>
public static PWM PWM1 = new PWM(PWM.Pin.PWM2);
public static PWM PWM2 = new PWM(PWM.Pin.PWM1);
/// <summary>
/// Create LCD
/// </summary>
public static AF10216A myLCD = new AF10216A("COM4");
/// <summary>
/// Set up dSpin items
/// </summary>
// Initialize flag and busy ports for all dSpin controllers
public static InputPort flagPort = new InputPort((Cpu.Pin)FEZ_Pin.Digital.Di50, false, Port.ResistorMode.Disabled);
public static InputPort busyPort = new InputPort((Cpu.Pin)FEZ_Pin.Digital.Di47, false, Port.ResistorMode.Disabled);
public static UInt32 dSPIN_rx_data = 0;
public static dSPIN_RegsStruct_TypeDef dSPIN_RegsStruct;
public static dSpin myL6472 = null;
/// <summary>
/// X Axis configuration
/// </summary>
public static SPI.Configuration xAxisConfig = new SPI.Configuration((Cpu.Pin)FEZ_Pin.Digital.Di49,
false, // Chip Select, active-low
1000, // 1000 (nanoseconds?) setup time
1000, // 1000 (nanoseconds?) hold time
true, // Clock low on idle
true, // Data valid on falling edge
5000, // 5Mhz Clock Rate
SPI.SPI_module.SPI2); //SPI device 2
/// <summary>
/// Y Axis configuration
/// </summary>
public static SPI.Configuration yAxisConfig = new SPI.Configuration((Cpu.Pin)FEZ_Pin.Digital.Di48,
/// <summary>
/// R Axis configuration
/// </summary>
public static SPI.Configuration rAxisConfig = new SPI.Configuration((Cpu.Pin)FEZ_Pin.Digital.Di51,
/// <summary>
/// Default method
/// </summary>
// Initializes Motor Controllers
InitializeMotors();
// Write to LCD
myLCD.SendCommand(AF10216A.Commands.FormFeed);
Thread.Sleep(50);
myLCD.Print("600-0061-2");
Thread.Sleep(50);
myLCD.SendCommand(AF10216A.Commands.CR);
Thread.Sleep(50);
myLCD.Print("Optics Placement");
// Attach Event Handler to 'COM1'
COM1.DataReceived += new SerialDataReceivedEventHandler(COM1_DataReceived);
// Open Com port
COM1.Open();
// Attach events to Estop & LC Inputs
DIN3.OnInterrupt += new NativeEventHandler(DIN3_OnInterrupt);
DIN4.OnInterrupt += new NativeEventHandler(DIN4_OnInterrupt);
DIN6.OnInterrupt += new NativeEventHandler(DIN6_OnInterrupt);
// Set PWM pins low
PWM1.Set(true);
PWM2.Set(true);
// Set outputs low
WriteDigitalOutputs(0);
//Turn on LED
LED.Write(true);
// LED int
int i = 0;
// Check to see if there is data available, then process
if (isData)
ProcessData();
// If 500 ms have passed, blink LED
if (i > 50)
LED.Write(!LED.Read());
i = 0;
Thread.Sleep(10);
i++;
Thanks,
Tom
