I have just purchased the FEZ Spider and wanted to make sure that I am supposed to connect socket 8 and 11 in order to use two motor drivers? The .Net visual designer does not allow me to connect two drivers and I just want to be sure this is correct.
Worked fine for me in a quick test - have you maybe left the default Hydra mainboard on the designer instead of dragging a Spider mainboard in to replace it?
Could be because I created a new project and like magic it works!! Thanks alot.
