@ njbuch - Sure, now I’m having an issue just with the button event. Can’t even get to the Tunes event. Replaced the board with a brand new one and still having the same issue.
Here’s the output from the debug mode:
Found debugger!
Create TS.
Loading start at 807a53c, end 80a04c8
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: GTM.GHIElectronics.LED7C (4.3.8.1) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.8.1) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (4.3.8.1) Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Button (4.3.8.1) Attaching deployed file.
Assembly: HomebaseV3 (1.0.0.0) Attaching deployed file.
Assembly: GTM.IngenuityMicro.RfPipe (4.3.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.USBClientDP (4.3.8.1) Attaching deployed file.
Assembly: GTM.GHIElectronics.Tunes (4.3.8.1) Attaching deployed file.
Assembly: GHI.Usb (4.3.8.1) Resolving.
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Modules\LED7C\NETMF 4.3\le\GTM.GHIElectronics.LED7C.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Usb.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Mainboards\FEZCerberus\NETMF 4.3\le\GHIElectronics.Gadgeteer.FEZCerberus.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Modules\Button\NETMF 4.3\le\GTM.GHIElectronics.Button.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\IngenuityMicro\Microsoft .NET Gadgeteer\Modules\RfPipe\NETMF 4.3\le\GTM.IngenuityMicro.RfPipe.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Modules\Tunes\NETMF 4.3\le\GTM.GHIElectronics.Tunes.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Modules\USBClientDP\NETMF 4.3\le\GTM.GHIElectronics.USBClientDP.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘c:\HomebaseV3\HomebaseV3\bin\Debug\le\HomebaseV3.exe’, Symbols loaded.
Using mainboard GHI Electronics FEZ Cerberus version 1.3
A first chance exception of type ‘System.NullReferenceException’ occurred in GTM.GHIElectronics.Tunes.dll
Error invoking method “Gadgeteer.Modules.GHIElectronics.Button” (check arguments to Program.BeginInvoke are correct)
The program ‘[3] Micro Framework application: Managed’ has exited with code 0 (0x0).
Here’s the code: (I commented out the Network portion, had the same issue with that but that may be due to the Network cable not plugged in at bootup)
using System.Text;
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GHIElectronics.Gadgeteer;
using GT = Gadgeteer;
using Gadgeteer;
using Gadgeteer.Modules.IngenuityMicro;
namespace HomebaseV3
public partial class Program
private string currentPolledTemp = string.Empty;
private bool receivedTemp = false;
rfPipe.DataReceived +=rfPipe_DataReceived;
button.ButtonPressed +=button_ButtonPressed;
Mainboard.SetDebugLED(false);
led7C.SetColor(LED7C.Color.Off);
led7C2.SetColor(LED7C.Color.Off);
//if (ethernetENC28.IsNetworkConnected)
// ethernetENC28.NetworkUp += ethernetENC28_NetworkUp;
void button_ButtonPressed(GTM.GHIElectronics.Button sender, GTM.GHIElectronics.Button.ButtonState state)
// when button is pressed - send out a signal to all receivers
rfPipe.SendData("fd power poll");
Thread.Sleep(750);
rfPipe.SendData("sd power poll");
Tunes.MusicNote note = new Tunes.MusicNote(Tunes.Tone.F4, 100);
tunes.AddNote(note);
tunes.Play();
// reset polled flag
void rfPipe_DataReceived(string val)
#region "fd opened"
if (val == "fd opened")
led7C.SetColor(LED7C.Color.Red);
led7C2.SetColor(LED7C.Color.Red);
Tunes.MusicNote note = new Tunes.MusicNote(Tunes.Tone.C4, 400);
tunes.AddNote(new Tunes.MusicNote(Tunes.Tone.C5, 500));
tunes.AddNote(new Tunes.MusicNote(Tunes.Tone.A2, 500));
tunes.Play();
Mainboard.SetDebugLED(true);
Thread.Sleep(30000);
return;
} // end if front door opened
#endregion
#region "sd opened"
if (val == "sd opened")
led7C.SetColor(LED7C.Color.Blue);
led7C2.SetColor(LED7C.Color.Blue);
tunes.Play();
return;
} // end if study door opened
#endregion
#region "yes fd power"
if (val == "yes fd power")
// play heard from the front door
Tunes.MusicNote note = new Tunes.MusicNote(Tunes.Tone.D4, 500);
tunes.Play();
} // end if we receive a front door poll response
#endregion
#region "yes sd power"
if (val == "yes sd power")
Tunes.MusicNote note = new Tunes.MusicNote(Tunes.Tone.C5, 200);
tunes.Play();
#endregion
#region "temperature signal received"
// receives: Temp: 84
if (val.ToLower().Substring(0,4) == "temp")
// check if the temp was triple digits
if (val.Length > 8)
// temp received, assign value to global
currentPolledTemp = val.Substring(7,2);
// raise polled flag
receivedTemp = true;
else // temp was double digits
currentPolledTemp = val.Substring(6,3);
#endregion
//void ethernetENC28_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
// // network is up
// if (ethernetENC28.IsNetworkUp)
// // process code
// ethernetENC28.UseStaticIP("192.168.17.17", "255.255.255.0", "192.168.17.1");
// WebEvent postTemp = WebServer.SetupWebEvent("bedroomTemp");
// postTemp.WebEventReceived += postTemp_WebEventReceived;
private string FormatDuration(TimeSpan x)
return x.Days.ToString("D") + ":" + x.Hours.ToString("D2") + ":" + x.Minutes.ToString("D2") + ":" +
x.Seconds.ToString("D2");
//void postTemp_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
// // web event
// var uptime = GT.Timer.GetMachineTime();
// if (receivedTemp)
// var HTML =
// Encoding.UTF8.GetBytes(
// @ "<head><style type=""text/css"">.style1{width: 100%;}.auto-style1 {text-align: center;}.auto-style2 {font-size: large;}.auto-style3 {text-align: right;}" +
// @ "</style></head><html><body bgcolor=""33cc33""><p><div class=""auto-style1""><span class=""auto-style2"">Uptime = " +
// FormatDuration(uptime) +
// @ "</span><br class=""auto-style2""/></div><table class=""style1""><tr><td class=""auto-style3"">Temp</td><td> </td><td>" +
// currentPolledTemp + " " +
// @ "</td></tr></table></body></html>");
// responder.Respond(HTML, "text/html");
// else
// // have not received temperature since bootup
// var HTML =
// "No Temperature Reading Since Startup" +
