Hello - I’m just getting my feet wet with my FEZ spider kit and I’m trying to use the camera class provided with the gadgeteer SDK to stream a bitmap from my third-party webcam to the included display.
I got the included camera to work just fine using the example included with the documentation, but i want to use my third party cam instead.
I have the USB host module hooked up with my webcam attached.
I can build and deploy my code, query the camera’s “ready” status (which returns “true”), but I can’t take a picture or stream a bitmap to the display.
When I take a picture using the joystick button, it does not show on the display. If I try to take another picture, and the debugger returns the message “camera is already taking a picture”
I can post my code, but I just like to know if what I’m doing is feasible.
The Gadgeteer Camera class provided in the GHI SDK is “tuned” for the camera they sell. I suspect there might be some issue with matching resolutions.
The GHI camera has three resolutions. The camera has a property CurrentResolution which determine the resolution that is to be used. Try changing the resolution to see if you can find one that matches.
If you can’t get it working, then do a search for Web Camera on the wiki. You should be able to get it working if go directly to NETMF bypassing the Gadgeteer layer.
This assume that your camera is compatible and has a resolution that is acceptable for fast USB.
Although, I haven’t tried setting the camera res using the NETMF functions. That might be worth a try. I guess the “device not supported” message is confusing me b/c I don’t believe there is anything really special about this webcam.
Good to know, and yeah the T35 display supports 320x240 max anyway right.
Below are some specs on my camera, I’d like to know whether it’s a software or hardware issue since the only message I’m getting “USB device not supported” doesn’t give me any indication why it might not be supported. I’m using this camera for my project because of the form factor but I suppose I could replace with another if I had some way to know the replacement cam used standard classes and met the hardware requirements.
Device Type: Digital Camera
Manufacturer: Empia Technology
Model: Recognized as DEF-299B in XP hardware manager
Interface: USB
Just tested the cam over a USB 1.1 hub connected to WinXP machine based on Gus’s comment. The resolution defaulted to 352x288 and the video was shown properly.
When you used it on windows, did windows ask for drivers?
In other words, when you look under the name of the driver vendor in device manager, is it Microsoft?
You can also use GHI libs to read the device class/subclass to determine of it is standard USB video compliant device…you camera is probably not. USB video device class - Wikipedia
Yes - it asked for drivers and the driver manufacturer listed in device manager is Empia Technology.
I went into device manager and rolled the driver from the Empia driver to one provided by Microsoft and the camera displays properly using the Microsoft driver.
Gus - Sorry for the confusion. Just plugged the cam into an instance of XP where I had not previously installed the included drivers for the camera and windows does not ask for any drivers. It simply loads the camera as a device in My computer and I’m able to double click and view camera video stream and take pictures.
With the camera attached to the USB module on my fez, I execute the following code:
Using mainboard GHIElectronics-FEZSpider version 1.0
UsbHost ERROR : Use GTM.GHIElectronics.Camera for USB WebCamera support.
ID: 2699998812, Interface: 0, Type: 16
UsbHost ERROR : USB device not supported.
ID: 2699998812, Interface: 1, Type: 0
Checking the GADGETEER library code, for the USB Host module, I see that a WebCamera is not one of the supported devices. That is why you are getting the unsupported device messages.
The solution is to lie. Tell the designer that you are using the WebCamera but plug in the USB Host module. If the camera is compatible it should work.
Thanks Mike. Yeah that is essentially what I’ve been trying. I am using the gadgeteer camera libs but with the USB module actually plugged into the fez board and my third party webcam attached to the USB module. The camera would connect and return a “ready” status. I would invoke camera.TakePicture() but the PictureCaptured event would never get raised. If I tried to invoke camera.TakePicture() again, I would get a console message saying that the camera was already busy taking a picture.
So it gets weirder now. I decided to try another webcam that I had laying around, a Logitech Pro 4000.
Using the same code, the logitech camera never even raises the cameraConnected event.
So one camera is recognized by the board and returns a ready status but I can’t take a picture and the other camera is not recognized at all.
I think I may just order a new camera off the list here:
That way I’m certain I’ve got a UVC-compatible camera
Here is my code for more clarity; note: the only reason I’m using NETMF.USBHost is to inspect the attached device. I’m using the gadgeteer camera class for communicating with the cam.
Program.cs
using GHIElectronics.NETMF.USBHost;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
USBHostController.DeviceConnectedEvent += USBHostController_DeviceConnectedEvent;
camera.CameraConnected += new Camera.CameraConnectedEventHandler(camera_CameraConnected);
camera.PictureCaptured += new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
joystick.JoystickPressed += new Joystick.JoystickEventHandler(joystick_JoystickPressed);
// Do one-time tasks here
void USBHostController_DeviceConnectedEvent(USBH_Device device)
Debug.Print("ID: " + device.ID + ", Interface: " +
device.INTERFACE_INDEX + ", Type: " + device.TYPE);
void camera_CameraConnected(Camera sender)
Debug.Print("Camera Status: " + camera.CameraReady);
camera.CurrentPictureResolution = GTM.GHIElectronics.Camera.PictureResolution.Resolution320x240;
void joystick_JoystickPressed(Joystick sender, Joystick.JoystickState state)
Debug.Print("joystick pressed");
camera.TakePicture();
void camera_PictureCaptured(Camera sender, GT.Picture picture)
Debug.Print("gotta picture");
display.SimpleGraphics.DisplayImage(picture, 5, 5);
Program.generated.cs
// <auto-generated>
// This code was generated by the Gadgeteer Designer.
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
// </auto-generated>
using Gadgeteer;
public partial class Program : Gadgeteer.Program
// GTM.Module defintions
Gadgeteer.Modules.GHIElectronics.Display_T35 display;
Gadgeteer.Modules.GHIElectronics.UsbClientDP usbClient;
Gadgeteer.Modules.GHIElectronics.Camera camera;
Gadgeteer.Modules.GHIElectronics.Joystick joystick;
//Important to initialize the Mainboard first
Mainboard = new GHIElectronics.Gadgeteer.FEZSpider();
Program program = new Program();
program.InitializeModules();
program.ProgramStarted();
program.Run(); // Starts Dispatcher
private void InitializeModules()
// Initialize GTM.Modules and event handlers here.
usbClient = new GTM.GHIElectronics.UsbClientDP(1);
camera = new GTM.GHIElectronics.Camera(3);
joystick = new GTM.GHIElectronics.Joystick(9);
display = new GTM.GHIElectronics.Display_T35(14, 13, 12, 10);
First web camera (Empia) returns:
Program Started
ID: 2700022344, Interface: 0, Type: 16
ID: 2700022344, Interface: 1, Type: 0
Camera Status: True
joystick pressed
joystick pressed
Camera ERROR : Unable to take picture. The camera is already busy taking a picture.
Second web camera (Logitech Pro 4000) returns:
Program Started
ID: 2700022344, Interface: 0, Type: 0
ID: 2700022344, Interface: 2, Type: 0
joystick pressed
Camera ERROR : Unable to take picture. Camera is not ready. Is the Camera connected?
After reading about the USB spec and downloading a USB snooper, I’m thinking I may use the USBRawdevice classes to write my own driver for the webcam. Anyone have any examples of using the USBRawDevice classes to communicate with an isochronous device? I’ve seen the driver example for the mouse using the these classes. I used that example to find the correct endpoint and inspect the device configuration but now I need to transfer some data!
