Sounds like a bug. Something for GHI to take a look I guess.
@ andre.m -
and is it possible to plugin your sd card into your pc to check if your pc is able to see and read the file?
Mentioned in text that I could read/edit the bitmaps.
I’ll try your suggestion
Thank you…
@ andre.m -
Bitmap bitmap = new Bitmap(File.ReadAllBytes(pathFileName), Bitmap.BitmapImageType.Bmp);
Dang your smart!
Worked like a CHARM!
@ Fembot32 -
I will post code in Codeshare after I finish this reply.
Note that the code uses firmware 4.2.9.0 (new).
It should get you started.
