Hi, Ive just bought FEZ panda and am attempting to run it with FEZ connect Shield and used firmware version - of V 4.1.7.0
in .Net Micro Framework Development Tool when i click in target/configuration/network it show an error[i have plug FEZ connect shield in the panda ii and i got the error massage
" device has old or unsupported configuration"] and also my FEZ connect shield get heated
Fez shield uses Wiz5100 chip. You cannot set network properties via MFDeploy.
Wiz5100 chip also runs hotter than you might expect - search the net for many people asking about this; it’s usual that this occurs, but it could also be a sign that you have a wiring problem (doubtful).
Go over to the code website and find a project that uses Wiz5100 and try it out - I think you will find everything is operating as expected.
