Trouble getting started with TinyCLR
I tried to build and deploy Blinky program on a new PandaIII after I installed G80 Firmware.ghi
namespace TinyCLRApplication3
        public static GpioPin LED;
            var gpio = GpioController.GetDefault(); // Get the default GPIO controller
            LED = gpio.OpenPin(FEZPandaIII.Gpio.Led2);
            LED.SetDriveMode(GpioPinDriveMode.Output);
                LED.Write(GpioPinValue.High);
                Debug.WriteLine("Switch to high");
                Thread.Sleep(300);
                LED.Write(GpioPinValue.Low);
                Debug.WriteLine("Switch to low");
                Thread.Sleep(300);
I get the following message output:
Found debugger!
Create TS.
Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Core (0.1.0.0) Attaching deployed file.
Assembly: TinyCLRApplication3 (1.0.0.0) Resolving.
Assembly: TinyCLRApplication3 (1.0.0.0) needs assembly ‘GHIElectronics.TinyCLR.Devices’ (0.1.0.0)
Error: a3000000
Waiting for debug commands…
The program ‘[14] TinyCLR application: Managed’ has exited with code 0 (0x0).
I have removed references and readded a couple of times. I have cleaned and rebuilt project. Any other ideas?
How did you install your nuget packages?
I had to use the VS nuget manager command line to install them, before I could use the references.
@ mtylerjr -
I placed the two packages in a folder on my desktop. I then used the nuget manager within VS2017 to added a path to this directory.
@ mtylerjr -
I was able to get it to work. I used the “clear all caches” button within the Nuget Manager General section.
Thanks for your help.
