I’ve a modified code to transfer Bluetooth Data to PC. Using Tera Term I’ve figured out that this is working, but It’s having a latency and all the reading are comes after 5-6 seconds.
If there anyone who’s occurred such a problem , please help me to solve this. If you have any alternative way please post it as well. I’ve increased the baud rate but It’s the same output
@ andre.m - If you can give me your email I’ll send it to you
Here’s the Code
Declarations …
// Buffer for fast access of incoming data
static byte[] InputBuffer16 = new byte[UInt16.MaxValue + 1];
static UInt16 InputBuffer16WritePtr = 0;
static UInt16 InputBuffer16ReadPtr = 0;
// ArrayList to take data from the buffer, the contents of the ArrayList is then sent over the bluetooth module
ArrayList ALReadBytes16 = new ArrayList();
// Gives the timeinterval to take data from fast buffer to ArrayList
GT.Timer timerTakeToArrayList;
// const int StdTakeTime = 2000; // (in ms) if no new bytes are read from MyI2C_Ctrl work can begin
const int StdTakeTime = 200; // (in ms) if no new bytes are read from MyI2C_Ctrl work can begin
// Gives the timeinterval to transmit data over bluetooth
GT.Timer StoreTimer;
// const int StdStoreTime = 4000; // (in ms) 60.000 = 1 min
const int StdStoreTime = 400; // (in ms) 60.000 = 1 min
// Gives the timeinterval to write test data in buffer
GT.Timer FeedTimer;
const int StdFeedTime = 50;
//const int StdFeedTime = 5000;
//const int StdFeedTime = 3000;
//const int StdFeedTime = 300;
static int FeedPauseCounter = 0;
// Your choice: when this value is reached, i make a pause
static int FeedPauseCount = 10;
// Your choice: i make a pause of i.e. 2000 ms.
static int FeedPauseLength = 1000;
//Trigger Time
GT.Timer TriggerTimer;
const int TriggerTime = 3000;
//set up a timer, when it ticks Data from the fastbuffer are read to ArrayList and are sent to bluetooth module
timerTakeToArrayList = new GT.Timer(StdTakeTime);
timerTakeToArrayList.Tick += new GT.Timer.TickEventHandler(timerTakeToArrayList_Tick);
timerTakeToArrayList.Stop();
//set up a timer, when it ticks data from the ArraList are sent over bluetooth
StoreTimer = new GT.Timer(StdStoreTime);
StoreTimer.Tick += new GT.Timer.TickEventHandler(StoreTimer_Tick);
FeedTimer = new GT.Timer(StdFeedTime);
FeedTimer.Tick += new GT.Timer.TickEventHandler(FeedTimer_Tick);
//set up a timer to initialize Bluetooth some time after power up
timerBluetoothInit = new GT.Timer(WaitToInitTime, GT.Timer.BehaviorType.RunOnce);
timerBluetoothInit.Tick += new GT.Timer.TickEventHandler(timerBluetoothInit_Tick);
timerBluetoothInit.Start();
//set up at timer to reconnect if there is no connection
timerTestConnection = new GT.Timer(CheckConnectionTime);
timerTestConnection.Tick += new GT.Timer.TickEventHandler(timerTestConnection_Tick);
timerTestConnection.Stop(); //the timer is started in the intitialize timer event
// define a bluetooth module running on socket 9
Debug.Print("Program Message: Make Bluetooth module on Port 8");
bluetooth = new Bluetooth(9);
Debug.Print("Program Message: Make client to use Client Mode");
client = bluetooth.ClientMode;
bluetooth.PinRequested += new Bluetooth.PinRequestedHandler(bluetooth_PinRequested);
// need a handler for state changes and data recieved.//
bluetooth.BluetoothStateChanged += new Bluetooth.BluetoothStateChangedHandler(bluetooth_BluetoothStateChanged);
bluetooth.DataReceived += new Bluetooth.DataReceivedHandler(bluetooth_DataReceived);
// not needed in this application
//bluetooth.DeviceInquired += new Bluetooth.DeviceInquiredHandler(bluetooth_DeviceInquired);
// Handler for button pressed. Button is used to enter pairing mode.
//button.ButtonPressed += new GTM.GHIElectronics.Button.ButtonEventHandler(button_ButtonPressed);
TriggerTimer = new GT.Timer(TriggerTime);
TriggerTimer.Tick += new GT.Timer.TickEventHandler(Triggertime_Tick);
timerTakeToArrayList.Start();
StoreTimer.Start();
if (DataInput == Input.Test)
FeedTimer.Start();
Debug.Print("Program Started finished");
#region TriggerTime
void Triggertime_Tick(GT.Timer timer)
if (bluetooth.IsConnected)
Debug.Print("trigger has Activated");
// otherwise, just go into pairing mode.
timerTestConnection.Stop(); // No events from timerTestConnection
bluetooth.SetDeviceName(MyDeviceName);
Thread.Sleep(100);
bluetooth.SetPinCode(MyPinCode);
Thread.Sleep(100);
client.EnterPairingMode();
timerTestConnection.Restart();
CheckConnectionTimeDownCounter = 4; // Now wait 4 times the CheckConnectionTime 4 x 5 sec. until resetting the BT-module
#endregion
#region FeedTimer_Tick
void FeedTimer_Tick(GT.Timer timer)
if (bluetooth.IsConnected) // Write teststring in buffer only when bluetooth is connected
Debug.Print("________________________Feed timer ticked and bluetooth is connected");
compass.RequestMeasurement();
compass.MeasurementComplete += new Compass.MeasurementCompleteEventHandler(compass_MeasurementComplete);
FeedPauseCounter++;
if (FeedPauseCounter == FeedPauseCount)
FeedTimer.Stop();
Thread.Sleep(FeedPauseLength);
FeedTimer.Start();
Debug.Print("________________________Feed timer ticked but bluetooth is not connected, no feed to buffer");
void compass_MeasurementComplete(Compass sender, Compass.SensorData sensorData)
string[] DP = new string[3];
string thePackage;
DP[0] = "X Axis" +sensorData.X.ToString() + "\n";
DP[1] = "Y Axis"+sensorData.Y.ToString() + "\n";
DP[2] = "Z Axis"+sensorData.Z.ToString() +"\n";
thePackage = DP[0] + DP[1] + DP[2];
byte[] DataMessage = Encoding.UTF8.GetBytes(thePackage);
for (int i = 0; i < DataMessage.Length; i++)
InputBuffer16[InputBuffer16WritePtr] = DataMessage[i];
InputBuffer16WritePtr++;
#endregion
#region StoreTimer_Tick
void StoreTimer_Tick(GT.Timer timer)
if (ALReadBytes16.Count > 0)
//Debug.Print("_______________________StoreTimer tick, Array contains Data");
byte[] SendArray = (byte[])ALReadBytes16.ToArray(typeof(byte));
client.Send(SendArray);
ALReadBytes16.Clear();
//Debug.Print("________________________StoreTimer tick, could not send, not connected");
//Debug.Print("_______________________StoreTimer tick, Array is empty");
#endregion
#region timerTakeToArrayList_Tick
void timerTakeToArrayList_Tick(GT.Timer timer)
//Debug.Print("timerTakeToArrayList_Tick - Take data from buffer to ArrayList");
int Overflow16 = 0;
if ((int)InputBuffer16ReadPtr > (int)InputBuffer16WritePtr)
Overflow16 = 65536;
//Debug.Print(InputBuffer16ReadPtr.ToString() + " " + InputBuffer16WritePtr.ToString());
while ((int)InputBuffer16ReadPtr < (int)InputBuffer16WritePtr + Overflow16)
//Debug.Print("InputBuffer16[" + InputBuffer16ReadPtr + "] " + InputBuffer16[InputBuffer16ReadPtr].ToString());
ALReadBytes16.Add(InputBuffer16[InputBuffer16ReadPtr]);
//InputBuffer16[InputBuffer16ReadPtr] = 0xFF;
InputBuffer16ReadPtr++;
if (InputBuffer16ReadPtr == 0)
Overflow16 = 0;
#endregion
