No hard interrupts
Is there a debounce machinism for touch ?
On ST processors, only one interrupt can be active on a given pin-number within a port at a time. For example, if you have an interrupt on PA3, you cannot have one on PB3. PB4 is fine though. In this case, the touch interrupt is pin PE3, so you cannot have an interrupt on PI3, SYSD.
OK, thanks
We would need to connect am analyzer to see what is happening on the bus but can you for now catch and discard those exceptions?
I canât get it to give me any exceptions. Can you narrow it down some more?
It happens completely randomly. Just now, on first press after reset. It seemed to happen more often if I hold down. I am using the touchdown event. I have also used the touchmove. touchup didnât give any event.
Do you have any other code in your system or any devices connected to the UCM dev board beyond the display?
I am using CAN
Just for testing, create a brand new project and only add code to draw on the screen when a touch occurs. No CAN or anything else.
