Touch Inizalitation Issue
I’ve been working on the touch screen and try to make some customize buttons without glide. When the programs starts the first image appears just a fraction of time and then dissapears turning the entire screen blank. If I touch the screen the program responds as expected printing the image back.
I Think is a Touch inizalitation problem, I don’t have this problem when I use the screen for printing images only (without touch events).
using System.Collections;
using Microsoft.SPOT.Touch;
using Microsoft.SPOT.Input;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp6
    public partial class Program
        public Bitmap plantilla = new Bitmap(Resources.GetBytes(Resources.BinaryResources.plantilla),Bitmap.BitmapImageType.Jpeg);
        public Bitmap imagen1 = new Bitmap(Resources.GetBytes(Resources.BinaryResources.Img1), Bitmap.BitmapImageType.Jpeg);
        public Bitmap imagen2 = new Bitmap(Resources.GetBytes(Resources.BinaryResources.Img2), Bitmap.BitmapImageType.Jpeg);
        public Bitmap imagen3 = new Bitmap(Resources.GetBytes(Resources.BinaryResources.Img3), Bitmap.BitmapImageType.Jpeg);
        public Bitmap imagen4 = new Bitmap(Resources.GetBytes(Resources.BinaryResources.Img4), Bitmap.BitmapImageType.Jpeg);
        public bool estatus = false;
            //Touch.Initialize(Application.Current);
            //displayTE35.SimpleGraphics.AutoRedraw = true;
            button.ButtonPressed += new Button.ButtonEventHandler(presionar_boton);
            //button.ButtonReleased += new Button.ButtonEventHandler(soltar_boton);
            displayTE35.WPFWindow.TouchDown += new Microsoft.SPOT.Input.TouchEventHandler(touch_D);
            //displayTE35.WPFWindow.TouchMove += new Microsoft.SPOT.Input.TouchEventHandler(touch_M);
            //displayTE35.WPFWindow.TouchUp += new Microsoft.SPOT.Input.TouchEventHandler(touch_U);
            displayTE35.SimpleGraphics.Clear();
            displayTE35.SimpleGraphics.DisplayImage(plantilla, 0, 0);
            this.plantilla.Flush();
            //Debug.Print("Program Started");
            displayTE35.WPFWindow.Invalidate();
        private void touch_D(object sender, Microsoft.SPOT.Input.TouchEventArgs e)
            if ((0 < (uint)e.Touches[0].X && (uint)e.Touches[0].X < 68) && (177 < (uint)e.Touches[0].Y && (uint)e.Touches[0].Y < 240))
                //displayTE35.SimpleGraphics.Clear();
                displayTE35.SimpleGraphics.DisplayImage(imagen1, 48, 23);
            else if ((73 < (uint)e.Touches[0].X && (uint)e.Touches[0].X < 160) && (177 < (uint)e.Touches[0].Y && (uint)e.Touches[0].Y < 240))
                displayTE35.SimpleGraphics.DisplayImage(imagen2, 48, 23);
            else if ((164 < (uint)e.Touches[0].X && (uint)e.Touches[0].X < 240) && (177 < (uint)e.Touches[0].Y && (uint)e.Touches[0].Y < 240))
                displayTE35.SimpleGraphics.DisplayImage(imagen3, 48, 23);
            else if ((246 < (uint)e.Touches[0].X && (uint)e.Touches[0].X < 320) && (177 < (uint)e.Touches[0].Y && (uint)e.Touches[0].Y < 240))
                displayTE35.SimpleGraphics.DisplayImage(imagen4, 48, 23);
        private void presionar_boton(Button sender, Button.ButtonState state)
            if (estatus == false)
                Mainboard.SetDebugLED(true);
                button.TurnLedOff();
                estatus = true;
                Mainboard.SetDebugLED(false);
                button.TurnLedOn();
                estatus = false;
@ D&I - https://www.ghielectronics.com/docs/162/touch#3181 should help, as should the Glide source itself. Do keep in mind that Gadgeteer SimpleGraphics and WPF do not interact too well.
Thanks John.
What could be the best way to use the touch screen and print images at the same time? Is there any replace for SimpleGraphics or WPF?
@ D&I - Take a look at the samples under Documents/TouchPanel, they have a few examples on using touch.
