ToString argument error
I am trying to format a double into exponential format:
            double pe = 0.01;
            string sss = pe.ToString("0.#E+00");
I get exception “Exception was thrown: System.ArgumentException”
I also get the error if I use
String.Format("{0:0#E+00}", pe)
@Joel_Riley perhaps document what formatting options are supported?
I am having a similar issue. Say I have an enumeration:
enum Color { Red, Green, Blue },
Create an instace of the enum:
private Color color = Color.Green;
Then the 2 lines below through “Exception was thrown: System.ArgumentException”:
string ColorName = color.ToString();
ColorName = Color.red.ToString();
There is known issue with enum and “ToString()”
Unfortunately, TinyCLR can’t support everything you’ll find in desktop .NET C#. We had to make some compromises to fit everything on small embedded systems and still leave room for your application.
There’s always a workaround – what about this:
double pe = 0.01;
double exponent = System.Math.Floor(System.Math.Log10(System.Math.Abs(pe)));
string sss = (pe / System.Math.Pow(10, exponent)).ToString() + "E" + ((exponent < 0.0) ? "" : "+") + ((int)exponent).ToString("D2");
This seems to work, but somebody will probably come up with a solution using half the code. :nerd_face:
