TinyCLR OS 2.0 - FileStreaming
is there any command
  • for file DELETE on USB / SD CARD …
    there’s already sample
    - how to create ,
    - read and write
but there’s no sample how to delete it ???
or i can’t figure it .
try to use
 var drive = GHIElectronics.TinyCLR.IO.FileSystem.Mount(storageController.Hdc);
  drive.Delete("path");
Let us know if that works or not !
do not work ?
(Maybe I am using SD CARD)
(and no error during calling this) !!!
var  sd = StorageController.FromName(SC20100.StorageController.SdCard);
 /* set drive */
var  drive = FileSystem.Mount(sd.Hdc);
string filename="test.txt";
var directory = new DirectoryInfo(drive.Name);
var path = $@"{directory}{filename}";
drive.Delete(path);
Mean doesn’t work?
Doesn’t work :unamused:
