I am working on using an STM32F405RGT6 processor (same as Fez Cerbuino/Cerberus) for my Juno project and wondering about the following being fully available in TinyCLR for this device?
PWM (DC motor control)
GPIO (Motor direction control)
UART x 1 (RS485 comms from the Raspberry Pi3 (via custom HAT)
INTERRUPT INPUTS (encoder inputs from DC motor)
I am pretty sure most of this is already there except for the interrupt inputs.
I had no real idea of the physical size but it was based around the Raspberry Pi 7" LCD display and I cut out the front panel for it at the weekend and when I saw the size, I realise this is going to be a lot bigger than I thought it would be. The diameter of the front panel is 220mm.
Just waiting for some parts to arrive to check details and I should be ordering the 3D printed plastic parts next month.
The whole design once I have built and checked everything will be released as open source.
Thanks Gus. This will be my first time to use TinyCLR. @mifmasterz is always asking when I will use it and we had a chat at a recent Atmel ATSAM4L day and decided we should learn how to port it so I have an Atmel ATSAM4S board on the way today that I plan to use as a test for porting TinyCLR to.
The Cerbuino will mean my motor controller board will work out of the box
