TinyCLR library for the ADS1115 Analog-to-Digital Converter
Example:
using System.Diagnostics;
using GHIElectronics.TinyCLR.Devices.I2c;
namespace Monoculture.TinyCLR.Drivers.ADS1115.Demo
    class Program
        static void Main()
            ReadSingleEnded();
            //ReadDifferential();
            //ContinuousConversion
            //Comparator
        private static ADS1115Driver GetDevice()
            var settings = ADS1115Driver.GetI2CConnectionSettings(ADS1115Address.Gnd);
            var controller = I2cController.FromName(G120E.I2cBus.I2c0);
            var device = controller.GetDevice(settings);
            return new ADS1115Driver(device);
        private static void ReadSingleEnded()
            var device = GetDevice();
            var ch1Millivolts = device.Read(ADS1115MultiplexerMode.SingleEnded0);
            var ch2Millivolts = device.Read(ADS1115MultiplexerMode.SingleEnded1);
            var ch3Millivolts = device.Read(ADS1115MultiplexerMode.SingleEnded2);
            var ch4Millivolts = device.Read(ADS1115MultiplexerMode.SingleEnded3);
            Debug.WriteLine($"Channel #0: {ch1Millivolts}");
            Debug.WriteLine($"Channel #1: {ch2Millivolts}");
            Debug.WriteLine($"Channel #2: {ch3Millivolts}");
            Debug.WriteLine($"Channel #3: {ch4Millivolts}");
        private static void ReadDifferential()
            var ch01Millivolts = device.Read(ADS1115MultiplexerMode.Differential01, ADS1115PgaScaling.One);
            Debug.WriteLine($"Channel #0: {ch01Millivolts}");
        private static void ContinuousConversion()
            device.StartContinuousConversion(
                ADS1115MultiplexerMode.SingleEnded0,
                ADS1115PgaScaling.TwoThirds,
                ADS1115SampleRate.X128Sps);
            for (var i = 0; i < 100; i++)
                Thread.Sleep(10);
                var adc = device.GetLastConversion();
                var mv = device.ConvertMillivolts(adc, ADS1115PgaScaling.TwoThirds);
                Debug.WriteLine(mv.ToString());
            device.Stop();
        public static void Comparator()
            const ushort lowThreshold = 0;
            const ushort highThreshold = 1000;
            device.StartComparator(
                lowThreshold,
                highThreshold,
                ADS1115SampleRate.X128Sps,
                ADS1115ComparatorMode.Traditional,
                ADS1115ComparatorPolarity.ActiveHi,
                ADS1115ComparatorLatching.NonLatching,
                ADS1115ComparatorQueueMode.OneConversions);
Thanks for sharing. What are you doing with this ADC? Just curious :slight_smile:
Hi Gus,
I’m using it to monitor 3 millivolt range sensors and to monitor the battery level for my device. I’m sure I could probably have used the on-board ADC with some sort of mux / amplifier circuit but I already had one of these lying around and it kind of did everything I wanted already.
