I have ported Electron board Which generates: hex, bin, …
I would like to generate glb file from them.
In Cerb configuration, there is : “ImageGenParameters:0x526603B1 0xE16B218D 0x08008000 0x000B8000”
I Wonder where come from values: 0x526603B1 and 0xE16B218D ?
They are magic numbers for the GHI Bootloader that are unique to each device. A glb file is only useful if you have a GHI bootloader for a given device.
Can TinyClr Config use hex or bin file ?
The aim is to update a board with TinyClr Config Which don’t have a bootloader: Electron boards from @Justin. If I can use Firmware Update button of TinyClr Config, it will be marvelous !
Unfortunately it cannot. Each processor manufacturer has a different way of programming. TinyCLR Config only knows how to update the firmware on devices that have a GHI Bootloader.
@Bauland as for getting the Electron from @Justin flashed with some binaries and start coding c# you may wanne have a look on the nanoFramework Landing Page for general background info or download images from here for more specifics about the Electron board or see on hackster for a little blinky with code example.
@_Peter Thanks for your reply. I know how to deploy firmware on Electron. (I use DfuSeDemo and dfu manager to generate the dfu file), but I would like to do it with TinyClr Config which, if it would be possible, will be easier, as all the other board I have can use it (FEZ Spider, FEZ Cerberus, …). But it appear that only glb file can be deployed with TinyClr.
It’s unlikely for the foreseeable future. Technically TinyCLR Config only requires a serial port that responds to the commands the GHI Bootloader makes available. So you could in theory write your own loader
